How to determine what Materials go with which objects???
5 posts • Page 1 of 1
cosrush
Post by cosrush » Wed Mar 12, 2008 4:26 am
I have a scene and have many materials from 1 upto 30.
Some are textured, therefore how can I tell which material relates to which object?
Example:
One object is plain coloured and uses the Phong setting
another is textured and uses the Matt setting.
Looking in the materials there is 30 different ones.
How would I set the material setting for the 2x above objects?
I hope this makes sense.........
cosrush
Post by cosrush » Wed Mar 12, 2008 5:09 am
Oh and my textures are UV mapped...........
GNUdo
Post by GNUdo » Wed Mar 12, 2008 5:21 am
There is a python script named "Material Works" which can:
* Search for a material in all objects and replaces it with another material.
* Reduce the effect to all/visible/selected objects.
* Rename materials in a list of all materials - no need to go the the object.
* Show who is using the material.
* Calculate the sum of surface areas using material.
* Assign material to selected faces or objects.
You can find it at http://blender.chaloupkovi.cz
Hope it helps,
Ciao
cosrush
Post by cosrush » Wed Mar 12, 2008 5:38 am
Thanks for the reply.
Is there a normal way within blender/indigo to do this or is this the only way to do it???
cosrush
Post by cosrush » Wed Mar 12, 2008 5:57 am
Ok, ive worked it out.
Thanks
:D
