Transparent glass in indigo 0.9 , dont work.
- giorgiomartini
look , i think the settings are ok , why is it wrong ?
its the black cube in the window , i scaled it down.
- salon.jpg (142.91 KiB) Viewed 3192 times
- settings_glasstransparent.jpg (44.11 KiB) Viewed 3192 times
- cheese on toast2
I think, it happens mostly with concave meshes...
A check, which is able to do it right in every single case, is very hard to code, I guess... Normals should be checked by users.
Maybe a "noob reminder" option (turned on by default but easy to deactivate...), which tells you, that you didn't yet check the normals of object ABC..?
(nah... would be more annoying than helpful
