afecelis
by afecelis » Mon Sep 18, 2006 12:19 pm
Hi Radiance,
Once again I'd like to thank you and ask you if it were possible to include a material sample for a non-transparent mirror in your next correction (V0.12) since the three examples you include are all specular and transparent and more focused on representing glass.
Everytime I try to get a mirror I just get a black-non-reflective material.
Thanks for the effort put into this tutorial
regards,
Alvaro
afecelis
by afecelis » Mon Sep 18, 2006 2:27 pm
hehehe, thanks radiance, trying it out now!
ps. I've always wanted to ask you what you use for trees in your scenes. Do you place them directly in blender or do you add them later in postpro?
boweeb007
by boweeb007 » Mon Sep 18, 2006 11:34 pm
If it's still black, try disabling bidir.
afecelis
by afecelis » Tue Sep 19, 2006 12:53 am
thanks boweeb007, but I always disable bidir as adviced in the tutorial
I'll firsttry the settings radiance suggested and report back.
animelix
by animelix » Tue Sep 19, 2006 1:09 am
set the "ior" up to 5, i think then you get a perfekt mirror
afecelis
by afecelis » Tue Sep 19, 2006 4:31 am
animelix wrote:set the "ior" up to 5, i think then you get a perfekt mirror
thanks animelix, but you mean in a transparent material (raytransp) or a mirror material (raymirror)? IOR options are only available in glass material setup.
animelix
by animelix » Tue Sep 19, 2006 10:29 am
maybe there are different ways?
i took this and it worked well:
<material>
<name>Spiegel</name>
<specular>
<normal_reflectance>300.87</normal_reflectance>
<ior>5.0</ior>
<transparent>false</transparent>
<rgb_absorptivity>0 0 0</rgb_absorptivity>
</specular>
</material>
(i think the high value on "normal_reflectance" is important too,
transparent on "false"
(I had to edit this):)
animelix on Tue Sep 19, 2006 11:06 am, edited 1 time in total.
afecelis
by afecelis » Tue Sep 19, 2006 10:51 am
thnx animelix!
your code works cool. I'll save it as a template to modify my xmls whenever I need a mirror material.
I'll post a screenie after some more rendering passes.
animelix
by animelix » Tue Sep 19, 2006 11:07 am
while you answered i edit the post
afecelis
by afecelis » Tue Sep 19, 2006 1:41 pm
hehehe, and what did you change? The code is the same I had copied before.
And here it is! finally
MIRROR!hehehehe
thanks y'all, thanks animelix!
