Sun light -very burn
6 posts • Page 1 of 1
jansan
Post by jansan » Mon Mar 05, 2007 12:43 pm
I am working this vestibulo, with Blendigo 0,7 t5 B4 although, already manages to combine sun with rlight as soon as I put the sun burns the image, as I can, to lower the intensity of iluminacion of the sun, I have varied all the parametros and nothing, When I open with violet and I fit it some rlight put grays
Estoy trabajando este vestibulo, con Blendigo 0.7 t5 B4
aunque, ya logre combinar sun con .rlight en cuanto pongo el sol
se quema la imagen , como puedo ,bajar la intensidad de la iluminacion del sol?, he variado todos los parametros y nada.,
Cuando lo abro con violet y hago ajustes algunos rlight se ponen grises
[img=http://img246.imageshack.us/img246/6537/nochecf5.th.jpg]
jansan
Post by jansan » Mon Mar 05, 2007 1:17 pm
Before tonemapping in Violet
paulo_gomes
Post by paulo_gomes » Mon Mar 05, 2007 1:26 pm
:shock:
maybe the scale of the model?
neepneep
Post by neepneep » Mon Mar 05, 2007 2:28 pm
Try set the tonemapping to Linear and set the scale to 0.004.
Also set the lights to blackbody and turn efficacy scale on.
Multiply the power by about 100 or so, for example. instead of using 200w, enter "20000w " and use 25 lm/w efficacy. Leave the temp at 5000 (and leave camera on 'E')
You can ignore the gain value because it won't affect anything since efficacy is on.
This is what I got from these settings:
jansan
Post by jansan » Mon Mar 05, 2007 11:56 pm
Thanks neepneep.
I believe that with your aid I have solved the problem that raises
Render of 10 minutes + tonemapping with violet
thank you very much
Gracias neepneep.
Creo que con tu ayuda he resuelto el problema que plantee
muchas gracias
Render de 10 minutos + tonemapping con violet
Post by Kram1032 » Tue Mar 06, 2007 2:26 am
Ok, Italians post bilingual.... I don't know why...
But why do spanish spearkers (Domenicanic Republicians :D) do this too, now?
*lol*
Really, it's not needed, everyone will understand even bad English...
:D ;)
Give it a try!
