Sry for this noob question:
How can i create a perfect reflective sphere in blender and render it in indigo?
i've tryied but i've a black hole instead the sphere!
Noob question!
danyolgiax
Noob question!
(Blender 2.46, Indigo 1.1.5, Blendigo 1.1.5)
danyolgiax
and for a perfect sphere??Kram1032 wrote:Set IOR >1(The higher, the brighter the reflection -> perfect mirror at 100000 IOR...
Which exporter do you use? And which Indigoversion?
If you use IndigoV 0.7.x, I'd say, you should use Blendigo!
If you use 0.6.x, you have to hand-edit the xml and increase the IOR value by your self...
in my signature:
(Blender 2.43, Indigo 0.7, Blendigo 0.7t5 beta 3)
Perfect sphere is easy too^^
Just create an icosphere (between 3-5 subdivs) and name it xyz.sphere
(I.E. Mirror.sphere)
As I don't know, if it should be in OB or in ME, I just rename both fields
This sphere-primitive doesn't work with meshlight, how ever....
With the same trick, you also can add an infinite plane: just name it xyz.plane
Sorry, I didn't look in your signature
danyolgiax
