Windows 7.0 64bits
Blender 2.49 64bits
Blendigo 2.4 Stable Update #2
Indigo 2.4.13 64bits
____________________
Not sure if it is systematic but I've noticed that the Gain value under the Environnement tab in Blendigo gets reset to 1.0 very often after reopening a saved file. Could there be a problem with the way the variable is saved?
Env Gain value gets reset to 1 after save
Re: Env Gain value gets reset to 1 after save
Got the exact same result again. Here is a little bit more info on my setup :
I have 4 machines.
MACHINE 1 : Workstation where I create stuff in Blender (also Indigo slave)
- V drive is a shared drive from Machine 2
MACHINE 2 : Indigo Master
- Local Drive shared with all other machines
MACHINE 3 : Indigo Slave
MACHINE 4 : Indigo Slave
Steps I took
1. Machine 2 has Blender open with file 3d.blend
2. Machine 1 has Blender open with file 3d.blend
3. I perform changes in Blender in Machine 1
4. I confirm that Env. Gain is set to 4.0 in Blender on machine 1
4. I save changes in Blender on Machine 1
5. I re-open 3d.blend on machine 2
6. I look at Env. Gain on Machine 2 and it is set to 1.0
7. I can confirm that all my other changes are actually there on machine 2 so the save/load actually worked.
Thanks in advance,
Again, what is strange is that I don't have that problem systematically. It seems intermittent?
I have 4 machines.
Steps I took
Thanks in advance,
Hello,
I just ran into another problem regarding gain value. This time on the material themselves. I have created a "Neon" material within a "Neon" light layer and I have specified this layer to be set with a Gain value of 0.008. When I launch my render with Indigo, it is set to 1.000. I have to manually change it back to 0.008.
This is not a problem with static images but with animation, it's quite a different story!!!
Any idea if this problem is generic or only related to my setup?
Hello Dougal, any idea what could be the problem?
Sorry I was meant to look into this, but development of the new exporter has been taking quite a lot of my Indigo-time. I'll probably have some spare time tomorrow and I'll try to catch up with a few 2.49 issues.
Indeed, the value was not specified in the list of settings to be saved to file. It'll be fixed in the next release.
Cool thanks,
Users browsing this forum: Bing [Bot] and 63 guests
