afecelis wrote:You nailed it down!
Works like a charm Jan! Superb work. How did you achieve it in the end?
Well, to be honest, Phil had nailed it some days ago, but there he created in fact just a direct commandline so that indigo ran with the same priority as all other programs, like blender for instance, and so making the system sluggy if you where rendering as well as editing something in blender.
In fact from the errors you all reported it however became clear that exporting the files did work, with as a result the conclusion that the Blender python function Blender.Get('datadir') does export the correct path including spaces in folder names. Since that datadir is where the cmd file resides the solution was to change the active directory to datadir first and then call the cmd file directly without the need of giving its location in a complete path as well... That cmd or batch file is needed because of the possebility to give the command 'start /b belownormal' that will let indigo run at less priority then anything else and so giving more resorces and processor time to others running simultaniously like blender.
Finally, to make absolutely certain this change of the active folder will not break anything else that's not foreseen the original active folder is reset after indigo is launched
If you've read this far you should take up programming yourself...
afecelis wrote:EDIT: I guess this might be considered the last "official" and evolved script for version 0.6 of Indigo, right?
Hmm, I don't know actually. There are still some things that could be enhanced in this one. Also I've no idea when the stable version of indigo 0.7 will see the light.
But whatever happens, first a little pause and do some real rendering I suppose...
Greetings from nighttime Amsterdam,
Jan
