Blendigo 2.2.11-c
enricocerica
Re: Blendigo 2.2.11-c
Post by enricocerica » Sun Jan 10, 2010 11:11 pm
Hi Dougal2,
I related a problem with nk materials on indigo node under Ubuntu when master started on Windows, I finally found the solution, I had to remove os.sep and replace it to force the "/" in the path instead of the "\" when windows is used to start the master, in that case Ubuntu does not recognize the path when loading the igs. Could you provide a solution to avoid that problem.
Thanks
dougal2
Post by dougal2 » Mon Jan 11, 2010 2:23 am
dougal2 wrote:Thanks Tom - the scene setup makes sense - I'm just trying to find the right code now to export it.
Bad news. The blender API has a big hole in the particle systems area. As far as I can see it is not possible to export the 'Group' Visualization type. :(
I am going to confirm this with Blender developers as soon as I can.
dougal2
Post by dougal2 » Mon Jan 11, 2010 2:33 am
dougal2 wrote:I am going to confirm this with Blender developers as soon as I can.
Confirmed. Though, the API in 2.5 allows access to this data, so I'll get it on the 2.5 TODO list.
Post by StompinTom » Mon Jan 11, 2010 2:59 am
Bah! All is lost!
Out of curiosity, is there a projected completion date for the 2.5 stuff?
Godzilla
Post by Godzilla » Mon Jan 11, 2010 3:08 am
the 2.5 project to be completed with the Durian film premiere in 2nd quarter 2010.
Source
Post by StompinTom » Tue Jan 12, 2010 12:34 am
I mean for Blendigo. Are we going to see an exporter before the official release of 2.5?
dougal2
Post by dougal2 » Tue Jan 12, 2010 1:27 am
StompinTom wrote:I mean for Blendigo. Are we going to see an exporter before the official release of 2.5?
Given that the official release of 2.5 (it may even be 2.6 by then) is quite a long way away, I should say probably yes.
Don't panic guys, you'll be the first to know when there's something new to play with :D
