Blendigo 2.2.8
Re: Blendigo 2.2.8
Post by Headroom » Sun Nov 29, 2009 4:20 pm
The new interface does not provide access to the A, B and C parameters anymore. That is somewhat limiting!
If, for example, a scene is created in an earlier version and has the Exponent defined as A=0, B=9500, C=500 then the new Blendigo seems to allow access only to the A value (for Exposure) and changing it would screw things up a bit. That's just one example.
Re: Blendigo 2.2.8
Post by Headroom » Sun Nov 29, 2009 4:29 pm
And still now way to change the backbody temperature of an emitter!
Which I reported to the initial thread announcing a new Blendigo interface. Did anyone in charge read that ?
I guess I still have to use 2.2.1 in parallel to fix some of the stuff that I cant do with the "improved" Blendigo :evil:
Godzilla
Re: Blendigo 2.2.8
Post by Godzilla » Sun Nov 29, 2009 4:36 pm
Am I the only person who finds it a little odd how the + and - buttons are set up?
Currently, you press a button designated as " - " to expand a menu, and a button designated " + " to minimize a menu. Shouldn't it be the other way around?
psor
Re: Blendigo 2.2.8
Post by psor » Sun Nov 29, 2009 4:59 pm
I do agree with you on that. It should be changed.
take care
psor
"The sleeper must awaken"
Jambert
Re: Blendigo 2.2.8
Post by Jambert » Sun Nov 29, 2009 8:31 pm
Godzilla wrote:Am I the only person who finds it a little odd how the + and - buttons are set up?
I do agree too :)
Maybe A, B, C value could be rename too, doesn't mean anything for much people...
Re: Blendigo 2.2.8
Post by Headroom » Mon Nov 30, 2009 3:35 pm
the A,B and C parameters are replaced with something more explanatory:
in the Material Editor:
Color (if type "Texture" is selected)
Brightness=A
Contrast=B
Saturation=C
Bump
Distance=A
no access to B (default is set to 0.01)
no access to C (default is set to 0)
Exponent
Intensity=A
no access to B (default is set to 10000)
no access to C (default is set to 1.0)
Displace
Distance=B
no access to A (default is set to 0.01)
no access to C (defaiult is set to 0)
I am running Blendigo 2.2.8 in parallel with the old 2.2.1. I just opened a fresh blender file, edited the values in 2.2.8 and looked where they were showing up in 2.2.1. As explained in my earlier post I am no friend of limitations for simplicities sake. A better explanation/documentation of these parameters for the above "slots" as for example given by WytRaven in this thread http://www.indigorenderer.com/forum/vie ... f=7&t=3064 would be much more helpful!
WytRaven
Re: Blendigo 2.2.8
Post by WytRaven » Tue Dec 01, 2009 1:40 pm
Headroom wrote:the A,B and C parameters are replaced with something more explanatory:
Brightness=A
Contrast=B
Saturation=C
Bump
Distance=A
Exponent
Intensity=A
Displace
Distance=B
Couldn't disagree more. Leave as is and read the bloody manual.
Re: Blendigo 2.2.8
Post by StompinTom » Tue Dec 01, 2009 4:22 pm
Agreed. I know they're a bit confusing at first, but it goes with learning the tool. Maybe if they were labeled 'intensity (a)', 'contrast (b)', etc. but never disable access to them! I use the b and c values for bump, exponent and displacement all the time.
Re: Blendigo 2.2.8
Post by OnoSendai » Tue Dec 01, 2009 5:23 pm
Well, as in the Indigo material editor, I would recommend that 'b' is given the less technical name 'scale' and 'c' is 'offset'.
dougal2
Re: Blendigo 2.2.8
Post by dougal2 » Wed Dec 02, 2009 1:27 am
dakiru wrote:Great! Thanks! :D
May I ask about the hybrid rendering method? Will it stay disabled in Blendigo options?
The button for this mode appears to have been overlooked, despite the rest of the code for it being present. I've added the button and it'll appear in the next release.
dakiru
Re: Blendigo 2.2.8
Post by dakiru » Wed Dec 02, 2009 1:47 am
Thanks a lot. And one more thing is not there are blackbody emitter settings :mrgreen:
dougal2
Re: Blendigo 2.2.8
Post by dougal2 » Wed Dec 02, 2009 1:55 am
Doug Armand wrote:A few things from quick play
Motion Blur is still screwed up - something went wrong between the last version of Smartdens, which did motion blur just fine, to Benn' version. That is still not working properly
I think I see the issue - as far as I can see it affects camera MB only? do you agree?
Here's a demonstration of the problem, it's evident if you render all frames in the animation:
dougal2
Re: Blendigo 2.2.8
Post by dougal2 » Wed Dec 02, 2009 2:40 am
Camera motion blur is fixed:
Doug Armand
Re: Blendigo 2.2.8
Post by Doug Armand » Wed Dec 02, 2009 2:42 am
Not sure what the cause is - only its effect. I only render single frames.
Below are 2 versions of same frame. Only difference is Blendigo version. There is both camera motion and object motion, ie wheels rotating.
In Smartdens version both motion blurs seem to render correctly. In 2.2.8... well I don't know if wheels are rotating correctly as I can't see then! :lol:
The camera is pretty much tracking the first car btw. This was all explained in earlier posts when Benn was 'updating' Blendigo :wink: .
Blendigo 2.2.21
Blendigo 2.2.28
I know it wont go down well but smartdens version worked ok - all it really needed was to have the render buttons placed at the top :wink:
Doug
Doug Armand
dougal2
Re: Blendigo 2.2.8
Post by dougal2 » Wed Dec 02, 2009 2:51 am
@Doug
The problem was that the camera MB start key-frame was always frame 1 rather than the current frame - so your broken render shows a blur covering time=0 to time=(current frame+exposure duration) instead of time=(current frame) to time=(current frame + exposure duration).
The result of this is that for any frame other than the first, the MB effect is too much by a factor of (current frame number).
Anyway, it should now be fixed :)
