Blendigo for v1.1.7
Regius
Vec3 ?
Post by Regius » Wed Aug 06, 2008 11:57 am
anybody knows what's this all about?
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: syntax error while parsing Vec3
Stopped.
What's Vec3 ?
Post by StompinTom » Wed Aug 06, 2008 12:02 pm
awesome stuff, SmartDen! wouldnt be doin this without your work!
Silverman
Re: Vec3 ?
Post by Silverman » Wed Aug 06, 2008 4:21 pm
Regius wrote:anybody knows what's this all about?
Stopped.
What's Vec3 ?
I hope someone knows. I'm getting it too. It seems to choke on the mesh. My model is a fluid simulation. :cry:
Jambert
Post by Jambert » Wed Aug 06, 2008 5:55 pm
Regius
Silverman
Same problem with a simple mesh created with "Curve2tree"
SmartDen
Post by SmartDen » Wed Aug 06, 2008 8:38 pm
please post a scene that throws error
Check normals, dude!
Jambert
Post by Jambert » Wed Aug 06, 2008 9:36 pm
Here is the scene, sorry and thx for next update :D
(it works with 1.0.9_2)
error vec3.rar
(35.44 KiB) Downloaded 257 times
Post by Borgleader » Wed Aug 06, 2008 10:01 pm
Jambert wrote:Regius
Silverman
Curve2tree have been mentionned earlier, im curious to se why it gives problems...
Silverman
Post by Silverman » Thu Aug 07, 2008 2:19 am
See the thread called "Syntax error parsing Vec3" under Bugs and Requests. I cross posted (sorry). Some info there and an example of rendered image.
palawat
Post by palawat » Thu Aug 07, 2008 2:23 am
Thank you very much, SmartDen. I'm downloading it now.
Really appreciate your time.
Cheers,
Jambert
Post by Jambert » Fri Aug 08, 2008 5:35 am
I found an error with "specular reflectivity material", it works with v1.1.5 :wink:
Post by Borgleader » Fri Aug 08, 2008 8:59 am
Smartden, looks like you're gonna have to clone it again for 1.1.8 :lol:
Bogey Jammer
Post by Bogey Jammer » Sun Aug 10, 2008 10:58 am
I also have this problem:
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 7464, column 5)
I opened the igs file and there's actually no *uv1* line..
Indigo 1.1.11 32bit + Blendigo 1.1.7
My render supercomputer:
  • Acer aspire 5612Zwlmi
  • Intel T2060 dual core 1.6 GHz
  • 1GB RAM
  • vista home premium 32bit
Big Fan
Post by Big Fan » Sun Aug 10, 2008 11:57 am
I think the issue is this: ono tightened up the criteria for uv
until smartden updates things either provide a uv map so there is info or delete the statements of the block <expose>.....</expose>
HTH
Pinko5
Post by Pinko5 » Sat Aug 16, 2008 8:05 pm
Tnx Smart i download it just now...
Luca. ;)
damiafix
Post by damiafix » Sun Aug 17, 2008 9:40 pm
Bogey Jammer wrote:I also have this problem:
Hi, very thanks for this 3d! I've the same problem, there are solutions?
Regards, Damiano
