Shaders in Blendigo
5 posts • Page 1 of 1
Termin8
Shaders in Blendigo
Post by Termin8 » Wed Mar 31, 2010 1:57 am
Hi all,
Is there a way to use different shaders in Blendigo (gradients, noise etc.)? It would be very useful for me. I know i can use textures, but what about standard shaders?
I like the way Indigo works with Cinema 4D shaders. Is there a way to do anything like that in Blendigo?
Thank you!
Best regards,
Alexander
Lenovo IdeaPad Y510: Core2Duo 2.1GHz, 2GB RAM, GeForce 8600M GT, WinXP Pro SP3, Cinema 4D 11.5/Blender 2.49 and Indigo 2.2.12 with Cindigo 2.2.11/Blendigo 32-bit
dougal2
Re: Shaders in Blendigo
Post by dougal2 » Wed Mar 31, 2010 6:26 am
Do you mean Indigo's ISL shaders, or Blender's Textures, or something else ?
There is already a request to bake blender's textures to image so that Indigo can use them, and ISL is supported via Blender Text objects.
Termin8
Post by Termin8 » Wed Mar 31, 2010 10:20 am
dougal2 wrote:Do you mean Indigo's ISL shaders, or Blender's Textures, or something else ?
Blendigo doesn't give me an opportunity to choose shaders. Let's say i want to use noise as a displacement map, or a gradient as an alpha map. How do i do that? Where do i find noise, gradient etc.?
Blendigo gives me 2 options: texture and shader. If i choose shaders, i can't find ones. The only thing i can find is "NONE" option.
Here is the screenshot of what i mean:
Thank you!
Regards,
Alexander
Post by Borgleader » Wed Mar 31, 2010 11:10 am
Thats because ISL shaders arent the shaders Blender has internally.
I'm guessing what you're talking about are these:
Those you can't use in indigo. What you can use is an ISL shader which is basically a text file, however as far as I know the only way to use it isn't through the exporter directly where you just pick "name.isl" file, but to paste the isl code inside the text window like so:
I believe there is a naming convention you have to follow for Blendigo to "detect" the shader, which is simply isl_(wtv you want here).
Termin8
Post by Termin8 » Wed Mar 31, 2010 11:18 pm
Borgleader, thanks for clarifying. That's exactly what i was looking for. However i'm not a code-master, so i'll rather go back to Cinema 4D and Cindigo for complex materials creation.
Thank you!
Regards,
Alexander
