[REQ] Region Rendering
11 posts • Page 1 of 1
Doug Armand
Post by Doug Armand » Tue Jan 12, 2010 12:28 am
In Blender you can select an area of the view for rendering by using SHIFT+B.
At the moment using render region works but with a problem. The region selected is the only part that gets rendered which is good - however it's seems the full size image is created while rendering. For example a 4500x4500 pixel image that has a region selected of only 150 x150 pixels will have the full 4500x4500 image created, but black, with the 150x150 area being rendered.This method still uses up a lot of RAM.
Any chance that only the selected region is sent for rendering? This would cut down massively on RAM usage particularly for testing purposes.
Hope that wasn't too long winded an explanantion of what I'm requesting :shock:
Doug
Doug Armand
Re: [REQ] Region Rendering
Post by StompinTom » Tue Jan 12, 2010 12:32 am
Agreed. I also thought that was weird...
Slows things down when tonemapping or working with lots of light layers for a tiny part of the overall image.
Post by suvakas » Tue Jan 12, 2010 12:39 am
How do you compose the final image after if you only have the region sized render?
It's hard to place it manually to the correct spot.
I think you are talking about something that is called "crop region" in Max. That's not currently supported by Indigo.
{edit]
It's very easy to implement though, as far as I can see. :wink:
Jambert
Post by Jambert » Tue Jan 12, 2010 12:48 am
suvakas wrote:How do you compose the final image after if you only have the region sized render?
{edit]
+1, that's it :)
could be usefull, actual region rendering isn't realy faster than fullsized rendering :?
Post by StompinTom » Tue Jan 12, 2010 1:00 am
I usually use region rendering just for testing so merging it into the final image isn't really a problem...
Though you could probably get it to spit out coordinates of the corners of the region relative to the whole image in the log or something. That way you just place that region at those coordinates et voila...
Doug Armand
Post by Doug Armand » Tue Jan 12, 2010 1:02 am
{edit]
crop region - region rendering I think they are one and the same?.
It's useful for checking say textures at full res on an object without rendering the whole thing. Not sure if its quicker but I would presume it would use less RAM?.
Doug
Doug Armand
Post by suvakas » Tue Jan 12, 2010 1:19 am
Indigo region should render faster, that the whole image. The point here is not to save your RAm, but to speed up rendering of some area. You could use it to render out that glossy glass material faster (if everything else is clean) and compose into initial image later. In production work with Vray I usually use region to change the color of a table for example without having to render the entire image again (enormous speed gain). For that it's needed, that the dimensions of the initial image remain the same so I can insert my region back easily in Photoshop.
There is also a region type called Crop in Max. That does exactly what you are after. Renders only the region and crops everything else.
Also there is a region type called Blowup that renders selected region using initial image resolution.
....there are a fiew more region types in Max, but this is a Blender sub-forum so ... :D
dougal2
Post by dougal2 » Tue Jan 12, 2010 1:24 am
I could certainly implement 'Crop' and/or 'Blow-up' options in Blendigo. I'll add it to the TODO list.
Post by suvakas » Tue Jan 12, 2010 1:31 am
dougal2 wrote:I could certainly implement 'Crop' and/or 'Blow-up' options in Blendigo. I'll add it to the TODO list.
You would need to use Indigo SDk to implement that. :wink:
I mean crop and blowup are currently not supported by Indigo UI.
dougal2
Post by dougal2 » Tue Jan 12, 2010 1:34 am
I was thinking more along the lines of recalculating the camera parameters at export time.
Post by suvakas » Tue Jan 12, 2010 1:36 am
Gotcha!
Would be cool to see this implemented also inside Indigo though.
Users browsing this forum: Bing [Bot] and 106 guests
