BACKGROUND IMAGE
14 posts • Page 1 of 1
grego
BACKGROUND IMAGE
Post by grego » Thu Jan 11, 2007 4:38 am
how can i place a background (for example an image) in indigo?
Give me printscreen please because i have already tried many settings in blender and indigo.
I think that it should be with an exr.file but i can't make it!
i'm not really a beginner, for example:
I have well understood
uv maps
lights
export
launch indigo
thanks in advance! Can i have please an answer as soon as possible because it's an work in process.
afecelis
Post by afecelis » Thu Jan 11, 2007 10:10 am
In the exporter options; change "Env Type" to "map", change it from "spherical" to "LatLong" and type in the name of your .exr image. The exr image must be placed at he same folder level as your xml.
That's it! :wink:
ps. you can convert hdri images to exr using the command line tool hdr2exr; grab it here:
http://hem.bredband.net/b230591/hdr2exr ... _win32.zip
ps2. Also check this thread:
http://www.indigorenderer.com/joomla/fo ... ht=hdr2exr
so also remember to use the search function as many of the questions have already been solved. :wink:
grego
Post by grego » Fri Jan 12, 2007 2:23 am
thanks a lot afecelis
:P
now it works!
for the beginner as me you must just change in the export settings, probe : none with probe: name of the image.exr.
sorry for my english
good day
:D
Toms
Post by Toms » Sun Jan 14, 2007 3:01 am
Hi, i got a problem with converting a hdr map to exr in console it says "can't lunch file sky0026.hdr in "rb" mode"
What to do in that situation?
afecelis
Post by afecelis » Sun Jan 14, 2007 3:10 am
Not sure but I think it has to do with the format of the hdr you're using. Is it a spherical probe? Try using a LatLong hdri instead, or convert your existing one to LatLong using HDRSHOP free. Or simply try with another hdr image and if it works try comparing them both to see what's different among them. Also, Indigo likes latlong exrs better; with spherical ones it crashes :?
Remember it has to be done thru a command line window (DOS mode) so it would be cool if you add the executable of hdr2exr to your system's PATH environment variables so you can invoke it from anywhere in your PC. Then all you gotta do is CD (change directory) to the folder where you got your hdri, and simply type "hdr2exr myimage.hdr myimage.exr" and you're done! :wink:
ps. Nice hood!! hehehehhe :wink:
Toms
Post by Toms » Sun Jan 14, 2007 3:18 am
Thanks, ill try out now and see what gonna happend.
Your hood looks well too :)
Toms
Post by Toms » Sun Jan 14, 2007 5:05 am
Ive downloaded the hdr shop v1, and i can't find and save the hdr in to proper way.
About the map, im using the free evermotion hdr maps, well maybe you have some direct links to latlong maps i would appreciate that.
afecelis
Post by afecelis » Sun Jan 14, 2007 5:40 am
the evermotion free maps are latlong; I've converted some of them to exr with no problem. Weird. :?
here's sky0050 converted for you to try:
http://afecelis.gdlib.net/Indigo/sky0050.zip
manitwo
Post by manitwo » Sun Jan 14, 2007 6:24 am
In case someone doesn't know:
to convert a (lets say) spherical hdr to a latlong hdr,
goto hdrshop->image->panorama->panoramic transformations
source image -> format = mirrored ball
destination image -> format = Latitude/Longitude
-> ok
Toms
Post by Toms » Mon Jan 15, 2007 12:10 am
Thanks afecelis the map works, but about that converting still don't work or i make something wrong.
Manitwo thanks it works.
afecelis
Post by afecelis » Mon Jan 15, 2007 2:19 am
Link to the "converting hdri images to exr" tutorial:
http://www.indigorenderer.com/joomla/fo ... php?t=1071
hope it helps! :D
Toms
Post by Toms » Mon Jan 15, 2007 2:49 am
:shock: it works thank you very much! i don't know what to say impressive tut :D
afecelis
Post by afecelis » Mon Jan 15, 2007 3:02 am
:D :D :D Glad it helped!
Now I'm interested in knowing what your error was, heheheh :wink:
Toms
Post by Toms » Tue Jan 16, 2007 4:32 am
Hi, ive got a last question about those hdr maps, there's any chance to get more sharpness, on that sky's(?) because it looks little pixelic.
Here's my test scene where is that sky.
http://img120.imageshack.us/img120/8370 ... 394gx9.png
Users browsing this forum: No registered users and 99 guests
