help with a semi transparent gem
5 posts • Page 1 of 1
Inlite
Post by Inlite » Fri Apr 24, 2009 8:01 pm
ok, ive bugged Smartden about this problem and he even fixed a file for me (it worked perfect) and i thought i had it sorted.....
it seems i dont, so i thought instead of bugging the poor guy again id ask around.
Im trying to render a simple gold ring with a gem in it and the gem keeps coming out black...
here are the screenshots:
here are the settings, i think i copied them correctly from the file Smartden fixed for me - but its not working now
blendigo gem.jpg (88.84 KiB) Viewed 11826 times
heres the render - could it be lighting? the normals are facing out, i checked
SmartDen
Re: help with a semi transparent gem
Post by SmartDen » Fri Apr 24, 2009 8:11 pm
turn off SSS
Check normals, dude!
Post by Kram1032 » Sun Apr 26, 2009 12:21 am
I hope, smoothing is turned off?
And yes, turn off SSS... -except the gem shouldn't be clear...
Post by CTZn » Sun Apr 26, 2009 1:53 am
Leave reinhard tonemapping alone, since the gem is the only light absorbing material in the sky (!) it has to be dark with reinhard tonemapping.
Also put the ring on some surface and use emitting ones for lighting.
Post by Kram1032 » Sun Apr 26, 2009 4:02 am
well, actually...
don't forget the gold^^ it also absorps. If it didn't, it'd be a perfectly grey-white reflector (a perfect mirror) rather than a golden one... :P
Users browsing this forum: No registered users and 89 guests
