Blendigo for 1.1.14
Post by Borgleader » Tue Feb 24, 2009 12:52 pm
Kram1032 wrote:hmm you'll rarely need >0.1 mm anyway but probably you're right^^
+1
I don't see why someone would run into this problem, but heck why put a limit when you dont need to.
SATtva_
Post by SATtva_ » Tue Feb 24, 2009 7:50 pm
Kram, besides LEDs there are many details with vertex below .1 mm distance (tiny bevel on many edges for example). LEDs are huge compared to this.
Psychotron80
Post by Psychotron80 » Tue Feb 24, 2009 8:18 pm
I perfectly agree.
By the way, notice that a very efficient human eye can resolve 0.35 mm spaced line pairs, at 1 m: http://en.wikipedia.org/wiki/Eye. So in object close-ups you definitely need to model details of .1mm...
SmartDen
Post by SmartDen » Tue Feb 24, 2009 10:08 pm
SATtva_ wrote:SmartDen, is it possible to expand "ray nudge" field (under Renderer tab in Blendigo) from the current 5-digit to 7-digit as per exported xml? The problem is that it's not possible to enter a value below 0.0001 -- Blendigo not rounds it up for display, but just drops any fractions below that value and exports 0.000000, the effect of which you may see here:
http://www.indigorenderer.com/joomla/fo ... 9318#69318
expanded
download from first page
Check normals, dude!
Psychotron80
Post by Psychotron80 » Tue Feb 24, 2009 10:09 pm
SmartDen thanks a lot!
SATtva_
Post by SATtva_ » Tue Feb 24, 2009 10:35 pm
SmartDen, thank you much!
Harry Beaver
Post by Harry Beaver » Fri Feb 27, 2009 4:31 am
@ SmartDen:
Is it possible in the next blendigo version to crank up the max number of threads ? Now it is stuck to 4 :(
Thanks
FakeShamus
Post by FakeShamus » Fri Feb 27, 2009 5:04 am
check the "auto choose number of threads" and indigo will use all your available cpu's
Post by Borgleader » Fri Feb 27, 2009 5:49 am
FakeShamus wrote:check the "auto choose number of threads" and indigo will use all your available cpu's
+1
@Harry Beaver: Wait...you have 8 cores???? :shock:
SATtva_
Post by SATtva_ » Fri Feb 27, 2009 7:01 am
Or he thinks he has. =)
Post by CTZn » Fri Feb 27, 2009 12:37 pm
And what ? I was using 4 back in 2004 !?
Harry Beaver
Post by Harry Beaver » Fri Feb 27, 2009 7:51 pm
yes, but not for animations, then you have to change it manually each time, and for still rendering too if you want to use 5,6 or 7 cores
Borgleader wrote:@Harry Beaver: Wait...you have 8 cores????
yes, it's not that special anymore
Jambert
Post by Jambert » Fri Feb 27, 2009 8:27 pm
So it's a bug :lol:
Harry Beaver
bi quad or proc with multithread?
Harry Beaver
Post by Harry Beaver » Fri Feb 27, 2009 9:59 pm
current config
64bit system 8g ram
Jambert
Post by Jambert » Fri Feb 27, 2009 10:43 pm
Harry Beaver
:) cool :)
