Exporting Problem
scott_s_06
Exporting Problem
Post by scott_s_06 » Mon Feb 16, 2009 12:50 pm
When I try and run the blendigo script I get the following problem as seen in the picture. I used the installer to get blendigo.
Vista 32bit
Python 2.5.4
Blender 2.48a
Indigo 1.0.9
How do I fix this?
I tried searching for tutorials on how to use blendigo, but I kept getting links to 404 not found pages.
Van Anders
Post by Van Anders » Mon Feb 16, 2009 12:58 pm
do you config the "indigowrapper.conf" file?
scott_s_06
Post by scott_s_06 » Mon Feb 16, 2009 2:38 pm
Not sure what that is, is that when you install blendigo and you have to tell it where blender is installed and where indigo is installed?
Post by Borgleader » Mon Feb 16, 2009 3:37 pm
scott_s_06 wrote:Not sure what that is, is that when you install blendigo and you have to tell it where blender is installed and where indigo is installed?
yes thats exactly it. "IndigoWrapper.conf" is the file containing that information.
It should be mentionned though that anyone using the .exe provided by Smartden doesnt have to touch this file because its created/edited automatically by the exe itself.
scott_s_06
Post by scott_s_06 » Mon Feb 16, 2009 3:41 pm
Ok, so does anyone know why it wont work?
Post by CTZn » Mon Feb 16, 2009 6:07 pm
From a non-blender user point of view, it could be that either indigoWrapper.conf is missing (probably not) or not set as required; 'datadir' seems to contain no path at all (string size = 0).
As suggested check the file again, maybe report its content here ? I don't know how it is read, maybe it can't assume an empty line as a beginning ?
:arrow: :arrow:
Van Anders
Post by Van Anders » Mon Feb 16, 2009 9:16 pm
\Blender Foundation\Blender\.blender\scripts\bpydata
-> indigowrapper.conf
open and edit it ( type where your indigo exe is).
if you did not find this file, you can download the .zip version and install manualy only the file into this directory)
8)
LONG LIVE FREE-RANGE TOMATOES!
scott_s_06
Post by scott_s_06 » Tue Feb 17, 2009 7:11 am
Yes that fixed it, I did not have indigowrapper.conf
Thanks for your help everyone!!!
nightshaade
Re: Exporting Problem
Post by nightshaade » Sat Apr 18, 2009 9:37 am
Sorry to bump thread. Have exact problem. Please more detailed explanation of indigowrapper.conf, can find this nowhere.
Post by Borgleader » Sat Apr 18, 2009 10:21 am
nightshaade wrote:Sorry to bump thread. Have exact problem. Please more detailed explanation of indigowrapper.conf, can find this nowhere.
It should be where Van Anders said it would be (look a few posts up) if its not there, then it hasnt been created. Are you using the blendigo installer or the zip file? Because the installer should technically create the file AND configure it for you.
nightshaade
Post by nightshaade » Sat Apr 18, 2009 11:41 am
Cannot find "Bpydata", Find "bpymenus". Installer used.
Post by Borgleader » Sat Apr 18, 2009 11:44 am
nightshaade wrote:Cannot find "Bpydata", Find "bpymenus". Installer used.
Well it pretty much has to be there or else you have none of the blender default scripts...
nightshaade
Post by nightshaade » Sat Apr 18, 2009 11:48 am
Blender 2.48 installed, Python 2.5.4 installed. Mayhaps security progs interfering?
Post by Borgleader » Sat Apr 18, 2009 12:03 pm
Nah, a security application wouldnt hide random folders like those...
nightshaade
Post by nightshaade » Sat Apr 18, 2009 12:04 pm
Yes. They are not there.
