Blendigo for v1.1.13
Yes it's possible Pxl666 i use igm file with "External" type shader only restriction that i know is in the name infact the Blender shader it must be the same name of the igm file...
ciao ciao
Luca.
ciao ciao
Luca.
thanks pinkoPinko5 wrote:Yes it's possible Pxl666 i use igm file with "External" type shader only restriction that i know is in the name infact the Blender shader it must be the same name of the igm file...
ciao ciao
Luca.
tried - doesn't work....either tried with extension - .igm and without - both fails - what i am doing wrong???
pixx attached
- materr2.jpg (31.36 KiB) Viewed 11485 times
- materr1.jpg (15.46 KiB) Viewed 11485 times
- materr3.jpg (8.36 KiB) Viewed 11486 times
i dont know...which version of indigo/blendigo are u using pinko? im using newest blendigo/indigo and tried several igm's but none of them works...are u under windows? can this be related to blender??Pinko5 wrote:I dont know if the error can be xxxxx.igm try without.....i am working in these days on a scene with 2 external shaders and it works fine...
ciao
Luca.
Juniorsatan
i use Indigo 1.1.14 and Blendigo 1.1.13 under windows xp pro, my shaders *.igm are both in the directory of my project i use Ruby and Diamond and they work very well... i see your image and the one reason that i could think is the extension in the name of your blender shader.....try without the extension (.igm)...
ciao
Luca.
ciao
Luca.
Juniorsatan
@ Pinko - i see theres a problem with internal material names - i mean names within an igm file...i didnt get it exactly right but i see there seems to be a problem. did u try any other matt? like http://www.indigorenderer.com/joomla/in ... Itemid=107
or http://www.indigorenderer.com/joomla/in ... Itemid=107
do they work for u?
cheers
do they work for u?
cheers
regarding IGM's i figured that one has to check the names WITHIN an IGM file and make sure they are the same as the names within blender/blendigo tabs (they very often are not...) and pray...i still have problems with textured/displaced/bumped matts - u have to check uv layer names within blender/blendigo tabs and within IGM....pain
anyone can tell is there workaround?
