AlphaChannel
by AlphaChannel » Fri Oct 24, 2008 9:22 am
I am new to the Indigo Renderer
I am unable to install the Blendigo exporter on Blender 2.48a.
I am receiving the following message when trying to install with the Windows Installer Blendigo_v109.exe:
Indigo not found in!
If somebody Knows what to do I would be much obliged.
Thanks in advance,
Avi
by Borgleader » Fri Oct 24, 2008 11:45 am
Because you specified the wrong directory?
You have to select the directory where indigo.exe is found. Or else it won't work.
AlphaChannel
by AlphaChannel » Sat Oct 25, 2008 3:01 am
Hi Borgleader,
I have tried to specify the directory that contains indigo.exe
Now I receive the follwing message when trying to install Blendigo:
Blender not found in c:\program files\Blender Foundation\Blender\Indigo_v1.0.9_3!
If I were to try to put the content of the Indigo_v1.0.9_3 in the Blender directory this can be problematic due to some *.dll files that overlap.
Much obliged if you have a solution.
afecelis
by afecelis » Sun Oct 26, 2008 4:09 am
Simply uncompress Indigo at C:\
Then modify the "IndigoWrapper.conf" file (that needs to be placed in blender's "bpydata" directory) with a text editor and adjust the path according to your directory structure.
AlphaChannel
by AlphaChannel » Sun Oct 26, 2008 7:08 am
Thunks Afecelis!
Now for the real stuff, lerning to work with the exporter.
by Borgleader » Sun Oct 26, 2008 1:44 pm
AlphaChannel wrote:Thunks Afecelis!
The exporter is rather "straightforward". I love it. You can try the "Conv" button if you,re not sure how to re-create your blender mats into indigo mats. although most settings are the same and i usually never bother changing the blender settings. I only create one set of mat settings, the indigo ones.
