.exr maps
Jacco
Post by Jacco » Sat Nov 04, 2006 7:50 am
No ground plane, else my car would be cut in half.
I'll try the RGB thing. allthough i'm not home for another two days.
Thanks Ian, thanks Indigo community.
Jacco;
Jacco
Post by Jacco » Mon Nov 06, 2006 12:53 am
turned my world colour to black in my .blend:
Jacco;
IanC
Post by IanC » Mon Nov 06, 2006 5:50 am
<env_map>
	<latlong>
		<path>glacier.exr</path>
		<gain>1.000</gain>
	</latlong>
</env_ma>
You need something like this and NO background element.
Check that the exr doesn't just have a grey floor, too.
Jacco
Post by Jacco » Tue Nov 07, 2006 8:06 am
I searched for the bit about the exr map in my xml. been doing that few a few days. never found it. something with the exports script I guess. where should I fit it in?
Jacco;
boweeb007
Post by boweeb007 » Tue Nov 07, 2006 8:16 am
Usually near the top - after camera and tonemapping settings. Would you mind posting your xml? You can omit the meshes if you want (would save space).
zuegs
Post by zuegs » Tue Nov 07, 2006 8:22 am
Hi Jacco,
don't guess too much, EXR works well for most peoples with exporter script :wink: ... just set the params on exporter GUI :roll: ("Env Type" to "Map", On "Probe" field you can set the EXR filename without path and ensure when starting indigo the EXR file sitting in same directory as the XML file, and so on ... :wink:
IanC
Post by IanC » Tue Nov 07, 2006 9:47 am
It must be in there though, you can see it in the reflections.
As said, it's early on in it. You can find it just by opening the file and you probably don't even have to scroll.
If you post the XML I'll highlight it for you/put it in.
Ian
Jacco
Post by Jacco » Wed Nov 08, 2006 7:39 am
zuegs wrote:Hi Jacco,
I only use the exporter. I filled in probe. IanC's though was the right one. I tilted the camera, my tests we're positive. now I'm getting the materials right and I'll do another render. finished the headlights, got rims from fried and put on the doorhandles and sprinklers.
Jacco;
Jacco
Post by Jacco » Wed Nov 08, 2006 8:02 am
<scene>
	<renderer_settings>
		<width>640</width>
		<height>322</height>
		<metropolis>true</metropolis>
		<large_mutation_prob>0.1</large_mutation_prob>
		<max_change>0.02</max_change>
		<max_num_consec_rejections>100</max_num_consec_rejections>
		<russian_roulette_live_prob>0.7</russian_roulette_live_prob>
		<max_depth>1000</max_depth>
		<strata_width>14</strata_width>
		<logging>false</logging>
		<save_untonemapped_exr>false</save_untonemapped_exr>
		<save_tonemapped_exr>false</save_tonemapped_exr>
	</renderer_settings>
	<tonemapping>
		<linear>
			<scale>1.0</scale>
		</linear>
		<reinhard>
			<pre_scale>1.000000</pre_scale>
			<post_scale>2.000000</post_scale>
			<burn>0.700</burn>
		</reinhard>
	</tonemapping>
	<include>
		<pathname>JaccoG_P-carGOOD7-materials.xml</pathname>
	</include>
	<env_map>
		<latlong>
			<path>pisa.exr</path>
			<gain>1.000</gain>
		</latlong>
	</env_map>
	<camera>
		<pos>-3.123152 3.429901 0.248474</pos>
		<up>0.003546 -0.014004 0.999896</up>
		<forwards>0.794133 0.607718 0.005695</forwards>
		<aperture_radius>0.001000</aperture_radius>
		<focus_distance>2.000000</focus_distance>
		<aspect_ratio>1.98758</aspect_ratio>
		<sensor_width>0.035000</sensor_width>
		<lens_sensor_dist>0.049431</lens_sensor_dist>
		<white_balance>E</white_balance>
	</camera>
beginning of my XML.
Jacco;
Jacco
Post by Jacco » Wed Nov 08, 2006 8:14 am
And, (sorry for my enthusiastic posting behaviour) here's an update:
Jacco;
Kosmokrator
Post by Kosmokrator » Wed Nov 08, 2006 8:55 am
looks good!let it cook up some more time and would be perfect...
Jacco
Post by Jacco » Thu Nov 09, 2006 12:20 am
I wanted to but indigo crashed after couple of minutes XD
Jacco;
skypa
Post by skypa » Thu Nov 09, 2006 12:55 am
Turned out great. Don't you dare posting another image unless it got > 1.5k mutations per pixel. ;)
edit: I'd say pull the camera back a bit and let the car breathe, since as of know the picture frame is pretty tight. :)
Jacco
Post by Jacco » Thu Nov 09, 2006 3:01 am
I will but indigo 0.6 test6 keeps crashing after ten minutes or something.
Jacco;
