Alpha textures - courtains
I'm in the middle of my work with my visualisation. I had created soft body croutains, BUT when i've put alpha texture i've realized that indigo can't see it. Does anyone know how to do it in other way?
You need to make a blended material, your original material blended with a null material..And then use your alpha map as the blend map...Here check out this tutorial it explains how to do it in more detail...
http://www.indigorenderer.com/joomla/fo ... php?t=1225
There is plenty of info about it on the forums, try doing a forum search if that doesn't help you.
- adrian2608
Hello
I've been made a blended material for example :
Cube with texture and another cube with null material ,(i don't know if i do that right ,null material i made it with alpha 0 )to blend map i load my alpha tex and when i start Indigo i become this communicate :
I know that i made something wrong but i don't know what
sorry for my English
P.S Maybe someone have a .blend file .
- aleksandera
- adrian2608
