"Scene must contain atleast one light source."
I already added an area light.
EDIT : now, it just displays a white screen and the consoles syas "done initial warmup."
Fatal error
rhoel_asia
SimonLarsen
Sorry, Indigo doesn't use point lights. You can use an HDRI Image as background for lightning, a sunlight or meshlights. If you want something similar to an arealight, make a plane and give it an emitter material. Then select the type of lightning in the enviroment category of the exporter to what you want.
rhoel_asia
Okay, that fixed it, I had two spots.alex22 wrote:Sorry, Indigo doesn't use point lights. You can use an HDRI Image as background for lightning, a sunlight or meshlights. If you want something similar to an arealight, make a plane and give it an emitter material. Then select the type of lightning in the enviroment category of the exporter to what you want.
Now rendering fine.
BTW< cannot upload .blend file to the site - extension not allowed.
Thanks for the fast reply.
Rhoel
