Blendigo 1.0.5 Beta
Neobloodline
Post by Neobloodline » Wed Feb 20, 2008 5:55 pm
Thanks smart, that was a nice one.
Gog
Post by Gog » Wed Feb 20, 2008 10:54 pm
Nice one SmartDen, thanks for the work.
Just an open thought I've taken to given the indigowrapper.conf a name change to match the blendigo version, means I can test a new variant alongside an old stable version. So at the moment I have IndigoWrapper101.conf and now IndigoWrapper105.conf and have the two blendigo variants available.
Anyone else do this?
SmartDen
Post by SmartDen » Wed Feb 20, 2008 11:05 pm
I do that too. And there was already a request that 'IndigoWrapper.conf' for each version gets a number. But I refused, because for the layman to unfathomable. If anyone would like, I like to explain how to 2 version can be run in parallel.
pxl666
bug?
Post by pxl666 » Thu Feb 21, 2008 11:24 am
hi guys
i have been using 104 version so far, but noticed today 105 so downloaded and tried...but it wont export scene that works with 104...> screen attached
is there any significant difference i shall be aware of??
indi 105 bug.jpg (82.6 KiB) Viewed 4399 times
jurasek
Post by jurasek » Thu Feb 21, 2008 4:21 pm
I got problem with instances. Sometimes when i append objects (tire and mirror here) from another .blend file, and 'duplicate linked', they appears flipped (mirrors) in Indigo. Tires turned into transparent boxes. Why? :wink:
greetz,
jur
Macrob
Post by Macrob » Fri Feb 22, 2008 7:47 am
Hi! The same problem here (pxl666s post).
Removing the ies-meshlight did render the scene but without the (I thought unsupported) curve object (not e mesh).
blendigo1.0.4 with background, ies-meshlight and curve-object
the same blend-file, but blendigo1.0.5 with background, no ies-meshlight and no curve-object :(
SmartDen
Post by SmartDen » Fri Feb 22, 2008 9:37 am
i'm sorry guys. As i rewrite export routines Curve and Text was broken. i have alredy fixed it, but i forgot fixed blendigo version an my work :oops: i'll upload it tomorrow. I'll check ies lights as well
JaMon_3D
Post by JaMon_3D » Fri Feb 22, 2008 11:49 am
Thank a lot Maestro SmartDen!!!
sk2k
Post by sk2k » Fri Feb 22, 2008 10:45 pm
thanks for the new version. :)
MfG
sk2k
SmartDen
Post by SmartDen » Fri Feb 22, 2008 11:28 pm
Blendigo Updated with some fixes. Please download it from first page.
Pinko5
Post by Pinko5 » Sat Feb 23, 2008 12:02 am
Tnx SmartDen!!!
Luca. ;)
pxl666
Post by pxl666 » Sat Feb 23, 2008 12:03 am
thx master - will try it ASAP
pxl666
Post by pxl666 » Sat Feb 23, 2008 12:26 am
smartden - could u consider adding an option to indigoresumer "start as a master" for easy resuming network rendering?
Macrob
Post by Macrob » Sat Feb 23, 2008 12:48 am
Works fine here with ies and curves :D
Thanks SmartDen
SmartDen
Post by SmartDen » Sat Feb 23, 2008 1:17 am
pxl666 wrote:smartden - could u consider adding an option to indigoresumer "start as a master" for easy resuming network rendering?
what resumer do you mean?
