memoryerror
4 posts • Page 1 of 1
Ziggy
memoryerror
Post by Ziggy » Wed Jan 30, 2008 3:19 pm
When I try and export my scene i get this error. have tried two releases of indigo now, a beta and a stable release and get the same message. anyone know what is causing it ?
Wedge
Post by Wedge » Wed Jan 30, 2008 4:45 pm
This is not something do to with Indigo, it is a Blender exporter script issue.
I don't want to call it a problem, it is a limitation. This error means you have a mesh in your scene that is too big for the exporter to export.
It will help to list which exporter you are using and make sure you use the correct exporter with the correct version of Indigo.
To fix this limitation you can either use a mesh not so detailed, or split the mesh up into more parts (I have never tried this), or use a different exporter that supports larger meshes.
enricocerica
Post by enricocerica » Wed Jan 30, 2008 5:59 pm
I meet this problem often with huge scenes and as Wedge said it, this is mainly due to big meshes, sometimes ending and restarting Blender may solve the problem. Another solution consists of reducing the subsurf values from 2 to 1 (wich are the default values) for the render value.
Ziggy
Post by Ziggy » Thu Jan 31, 2008 2:09 am
alright thanks for the help guys, Just tried lowering the subsurf levels like you said and they where to high :oops:
Thanks for the help :D
