Luca.
Blendigo for v1.0
Small request
Hi SmartDen. Thanks again for the exporter.
I was wondering if you could continue to name the Indigowrapper.conf
like you did in with ver.1.0.1 (Indigowrapper101.conf)
That way I can leave the other versions intact.
If not, I will just continue to edit the .py & .conf
I know the less you have to edit a file the better & I understand if
you don't feel this is a reasonable request.
Thanks for your time.
Eric
Eric
One little problem here. i use Blender 2.45, Indigo 1.0.1, Blendigo v104 and Python 2.5.1. After my first play with Indigo, I got this;
Fatal error;
SceneLoaderExcep: Found unexpected element 'aperture_shape' in element 'camera'. (Around line 50, column 9)
One thing that doesn't match the requirement is Python 2.5.1. Should I instead use 2.5?
I'm running on Pentium 4, 3.0 GHz, HT, 2.56 GB Ram.
Fatal error;
Cheers,
- ViennaLinux
- ViennaLinux
AFAIK, Blendigo should work on any system, if there is a Blender version for it, complied with Python 2.5...
Indigo is an other questions, but I saw some posts, that ppl got it working.
I think, it somehow even worked with wine
Oh, and the exporter didn't change that much. It wouldn't be too useful, to only add a screenshot.
Keeping in mind the matching version numbers is better
