Blendigo for v0.9
set RGB color to 0.8138, 0.9112, 1.000 and the gain to 14.589
or set RGB color to 0.1187, 0.13293, 0.1458 and gain to 100
both solutions should give the same right output (except if blendigo uses gamma correction for sss....
) you will tell us
damn i feel retard!!!!!
here is an example:
So in Blendigo will be:
Absorption: Gain: 1 values: 0.001 0.003 0.013
Scattering: Gain 100: values: 0.119 0.132 0.145
Then edit the mat file and change the RGB gamma to 1 (why is 2.2 default?)
Another thing i don't understand is:
Why the color doesn't change in blendigo visual colortab if i change the gain? Is it normal?
Bury me with spits
here is an example:
<medium>
<name>milk_scattering_medium</name>
<ior>1.35</ior>
<precedence>10</precedence>
<rgb>
<rgb>0.001 0.003 0.013</rgb>
</rgb>
<subsurface_scattering>
<rgb>
<rgb>11.873 13.293 14.589</rgb>
</rgb>
<phase_function>
<uniform/>
</phase_function>
</subsurface_scattering>
</medium> Absorption: Gain: 1 values: 0.001 0.003 0.013
Bury me with spits
2.2 gamma is to match the processing of colours in Indigo with what you see in Blender and other program's colour sliders
But if your using SSS RGB values from scientfic papers gamma has to be set to 1. Some exporters allow you to change the gamma, a good idea IMO
RGB will only go from 0 to 1 within 3D programs. That's why you won't see any change, this multiplier is only for Indigo which works on a greater range with spectral stuff.
SPIT!
SPIT!
ok someone help me with my confusion please
this gamma being 1.0 only applies to SSS if you want to use data from papers otherwise it continues to be 2.2, is that it?
all other gamma in indigo stays as 2.2 regardless?
and at the moment there is a bug in Indigo for SSS that renders for example milk orange, yes?
Surfing you want a button on the SSS UI to switch between the two gammas to make life easy?
I suppose I could do something about that for smartden if he is not around...
I dont think he likes my coding though
I agreezuegs wrote:i think gamma should be 2.2 only for real colors (diffuse and albedo). Most others as absorbtion, SSS and other funny stuff should have a gamma of 1.0 as this values express some special physical values (as absorption per meter stuff - look units in indigo-manual).
This way, users can use actual real-world values from papers and it makes sharing materials much easier between the different exporters if everyone is using gamma=1.0. (Sharing IGM files starts to get pretty confusing if everyone is using different gamma values).
Not really....Only the values that will be displayed on the second swatch. This only serves as visual feedback so you can see what Absorption and Scattering values are actually being exported. The gamma tag would be exported as 1.0 for absorption and scattering. Gamma tag would be 2.2 for all other situations.Kram1032 wrote:now, THAT's an interesting ideaso every value has to be corrected with gamma 0,45454545454545454545454545454545
(1/2.2)
