DEV-thread - Blendigo v0.8 - material-editor-exporter
SimonLarsen
Oh, didn't know about the other scripts. Thanks.Kram1032 wrote:hum, I can point you to two scripts, but actually, I didn't try Dif Trans, yet![]()
here http://www2.indigorenderer.com/joomla/f ... php?t=1997 (the post before my last, == the post before the last)
and
here http://www2.indigorenderer.com/joomla/f ... sc&start=0 (the 4 posts from bottom, on the first page)
mrCarnivore
Try this one. http://www2.indigorenderer.com/joomla/f ... 2302#22302mrCarnivore wrote:In the newestblendigo 0.8 version absorbtion still doesn't work! Can anybody pls fix this problem, so I can finally use blendigo 0.8?![]()
Also how far along is the material loading/saving?
It works fine, AFAIK. Material loading/saving is not implemented yet, but it will be immediately implemented when Ono defines the igm format
mrCarnivore
the .igm format was already agreed on in this thread:
http://www2.indigorenderer.com/joomla/f ... php?t=1687
I already tried the blendigo version you suggested. But to rule out any mistake on my part, I will delete all blendigo verions in my blender dir and then install that one again, to confirm this.
@SmartDen:
I'am working on this already... perhaps a bit slow
I finalized a xml parser that seems to work fine. So i'am working currently on some GUI objects (the blender draws) that directly interacts with the materials xml data (in memory and inside the blender scene file).
Still have to solve some tricky problems...
- joegiampaoli
- joegiampaoli
does it crash BlenderToIndigo?
Could you try to export this scene with the BlenderToIndigo exporter from http://wiki.blender.org/index.php/BlenderToIndigo (forum thread: http://www2.indigorenderer.com/joomla/f ... php?t=2037)? I wonder if it crashes with my script too. I use slightly different export procedure. If it crashes too, it is likely that the problem is not related to the exporters.joegiampaoli wrote:I mean it's really no big deal if you save your blend file before the export, but after all it's a bug, specially for those who are starting out with blender>blendigo>indigo
Just wondering.
