Instacing objects
3 posts • Page 1 of 1
danyolgiax
Instacing objects
Post by danyolgiax » Fri Apr 13, 2007 6:37 pm
in my scene i've a big duplication (SHIFT+D x 1000 times) of the same simple object...
can i load the object a single time and than create multiple instance to preserve memory usage?
Dox
(Blender 2.46, Indigo 1.1.5, Blendigo 1.1.5)
DaveC
Post by DaveC » Fri Apr 13, 2007 10:42 pm
Yes. Just use Alt+D instead of Shift+D. You can even set up a mesh and use dupliverts for instancing, if you wish.
Cire
Post by Cire » Sat Apr 14, 2007 5:33 am
DaveC wrote:Yes. Just use Alt+D instead of Shift+D. You can even set up a mesh and use dupliverts for instancing, if you wish.
Is Blendigo set up to do the same with meshes that have an Array modifier?
