Error : local variable ´face´referenced before assignment
5 posts • Page 1 of 1
jansan
Post by jansan » Tue Apr 10, 2007 7:55 am
UnboundLocalError: local variable ´face´referenced before assignment
It is the error that leaves me when doing to render to a file that matters from autocad and soon it publishes in Blender. Like adjustment the file to make render from Indigo (Blendigo)
Es el error que me sale al hacer render a un archivo que importe desde autocad y luego edite en Blender.
Como arreglo el archivo para hacer render desde Indigo
zuegs
Post by zuegs » Tue Apr 10, 2007 9:13 am
This happens when one of the objects in your scene has no faces, i think. I will add a filter in one of next Blendigo releases to ignore such objects and so prevent this error to happen.
DaveC
Post by DaveC » Tue Apr 10, 2007 10:12 am
That is what happened when I tried to export mancandy over to Indigo. I had to delete curves and stuff.
Anthony
Post by Anthony » Wed Apr 11, 2007 7:24 pm
Does this mean Armatures count as no faced objects cause that sucks
DaveC
Post by DaveC » Wed Apr 11, 2007 11:31 pm
I don't believe it was the armature. If armatures do cause a problems, you can just put them on a seperate layer in blender and turn the layer visibility off. I think it was some control device or curve or something. I managed to export mancandy in the end.
