Blendigo 4.2.2
Blendigo 4.2.2
Archive: https://downloads.indigorenderer.com/di ... 982b42.zip
Windows Installer: https://downloads.indigorenderer.com/di ... taller.exe
Should be compatible with Blender 2.78-
Changelog:
4.2.2
* Compatible with latest 2.79 builds
* Autoupdater
* Bugfixes: dupli lights, dupli light/lightlayer, exr export, uid bug, always default background bug, particle motion blur, external material
Changelog:
4.2.2
* Autoupdater
Re: Blendigo 4.2.2
Thanks for your reply. I downloaded the folder as you suggested - and again - there is no installer. I've attached a screengrab.
I am still unclear what to do next. The installer is missing. Do you know the path where I install this myself? Thanks.
Re: Blendigo 4.2.2
Hi, you can just move indigo_exporter folder to addons path, eg. <path to Blender>\2.79\scripts\addons\
More info about Blender path layout: https://docs.blender.org/manual/en/late ... ories.html
Or, you can zip indigo_exporter folder and install it from inside Blender using preferences/Add-ons/Install Add-on from File button.
- aleksandera
Re: Blendigo 4.2.2
Hi! First of all Thank you for developing the blender exporter!
Can you check the attached scene. The camera focus doesn't export correctly.
- Focus_Test.rar
- (72.31 KiB) Downloaded 1684 times
Re: Blendigo 4.2.2
Your problem has been solved in version 4.2.3.
You can use updater under addon preferences to directly update to this version, though if you use OSX, you might need to download it manually.
- aleksandera
Re: Blendigo 4.2.2
Thank you!
Re: Blendigo 4.2.2
Just update to version 4.2.3MZ wrote: ↑Tue Feb 19, 2019 2:53 amArchive: https://downloads.indigorenderer.com/di ... 982b42.zip
Changelog:
4.2.2
* Autoupdater
* Bugfixes: dupli lights, spanish dictionary dupli light/lightlayer, exr export, uid bug, always default background bug, particle motion blur, external material
geometry dash full game, spanish dictionary online
Re: Blendigo 4.2.2
Is there a timeline for availability of Blendigo in Blender 2.8 ?
The Blender Beta seem plenty stable for my needs and Will likely move to a Stable release very soon. It would be nice to be able to transition to 2.8.
Re: Blendigo 4.2.2
Hi, works on 2.80 are in progress. You can expect updates soon.
Re: Blendigo 4.2.2
Awesome! Thanks for the update!
Re: Blendigo 4.2.2
Is 2.80 still the latest update or has there been a newer version since then?
Re: Blendigo 4.2.2
@Stoffel how hard would it be to check that on Blender.org ?
Re: Blendigo 4.2.2
Great, looking forward to 2.80, thanks!
Ashley | https://www.paintersstjohnsnl.com/
Re: Blendigo 4.2.2
for the time being, 2.80 is the latest... 2.81 is to be released next week
Last time l checked, works w/ both
Re: Blendigo 4.2.2
I have Blendigo 4.2.2 enabled in the Bender 2.8 preferences, but it does not show up in the available render engine settings. Are you sure this works ?
Edit: Forget that. Found the solution in the "other" thread.
Users browsing this forum: No registered users and 106 guests
