please help..
4 posts • Page 1 of 1
BWETIK
please help..
Post by BWETIK » Tue Jan 23, 2007 10:34 pm
have a problem, just starting try to use indigo, and..
I working with blender export tutorial,
everything is great, but at final when i create a .xml,
and open it with command line, its opened, but with internet explorer, no with indigo :shock:
Maybe im idiot, but dont know what to do..
Thanks. Casper
DaveC
Post by DaveC » Tue Jan 23, 2007 10:40 pm
Yes, well, ah. What you're doing wrong is, you're opening the xml. What you should be doing is opening Indigo directly, then Indigo will open the xml. But first, you need to edit the inifile so that Indigo knows which xml file to open and where it is. Either that or you can open indigo in the cmd line with you xml path and filename as an argument.
Welcome to Indigo :)
BWETIK
Thanks!!
Post by BWETIK » Wed Jan 24, 2007 1:27 am
Thanks man, its working :D
Thanks a lot. Casper.
aleksandera
Post by aleksandera » Sat Mar 03, 2007 1:23 am
Also thanks!
had the same problem.
