Archive: http://downloads.indigorenderer.com/dis ... .8.5.0.zip
Windows Installer: http://downloads.indigorenderer.com/dis ... taller.exe
Changelog:
3.8.5.0
* Added arch glass option to specular material.
* Fixed particle export being slow.
* Fixed background rotation.
* Fixed parent visibility being ignored.
* When exporting animations, frames have a random seed, seeded by frame number.
Bug reports and comments welcome!
Blendigo 3.8.5.0
Re: Blendigo 3.8.5.0
Hello, I tried to install the zip file but got the following error messages. Could it be because I'm using version 2.7.0 of Blender?
File "C:\blender-2.70-windows64\2.70\scripts\modules\addon_utils.py", line 278, in enable
imp.reload(mod)
File "C:\blender-2.70-windows64\2.70\python\lib\imp.py", line 252, in reload
return module.__loader__.load_module(name)
File "<frozen importlib._bootstrap>", line 586, in _check_name_wrapper
File "<frozen importlib._bootstrap>", line 1023, in load_module
File "<frozen importlib._bootstrap>", line 1004, in load_module
File "<frozen importlib._bootstrap>", line 562, in module_for_loader_wrapper
File "<frozen importlib._bootstrap>", line 869, in _load_module
File "<frozen importlib._bootstrap>", line 313, in _call_with_frames_removed
File "C:\Users\frederic.brunelle\AppData\Roaming\Blender Foundation\Blender\2.70\scripts\addons\indigo\__init__.py", line 48, in <module>
imp.reload(core) #@UndefinedVariable
File "C:\Users\frederic.brunelle\AppData\Roaming\Blender Foundation\Blender\2.70\scripts\addons\indigo\core\__init__.py", line 61, in <module>
from indigo.core.util import getVersion, getGuiPath, getConsolePath, getInstallPath, count_contiguous
ImportError: cannot import name count_contiguous
EDIT : Flushed Blender directory, reinstalled (version 2.71) and installed blendigo 3.8.5 and it worked fine.
imp.reload(mod)
- aleksandera
Particle speedup works great!
Still only exporting visible particles, though... Any way to export full particle amount?
EDIT: Particle export also doesn't seem to work when the Display mode is set to Points (instead of Render). Could these two be related issues?
Bug: when Camera is set to Orthographic, it throws "local variable 'ws' referenced before assignment".
Oops, fixedStompinTom wrote:Bug: when Camera is set to Orthographic, it throws "local variable 'ws' referenced before assignment".
It seems this has been possible for a while now. Added it for the next releaseStompinTom wrote:Particle speedup works great!
https://code.google.com/p/blendigo/source/detail?r=55
Indigo unfortunately can't really render points, it needs some kind of geometry at least.
The points display mode is just to keep the viewport light, still need to export the geometry.fused wrote:Oops, fixedStompinTom wrote:Bug: when Camera is set to Orthographic, it throws "local variable 'ws' referenced before assignment".
Still hoping for some kind of point rendering someday
