I have changed the output path back to it's original purpose of specifying the render output path and fixed the issue where blendigo "forgets" the output path if it contains # characters.
The scene file will be saved into the render ouput path, but the name cannot be set anymore (if anyone needs that functionality back, I'd introduce a scene file name property).
[Animation] Exporter first creates blank frames
- Doug Armand
Re: [Animation] Exporter first creates blank frames
That's great - has the creation of blank frames also been fixed?
Doug
Doug Armand
Doug Armand
Well, yes, sort of:
fused wrote:The output path is used correctly now, that means Indigo will save the images with the same name as blender does. The blank frames are still written by Blender but Indigo will overwrite them as the animation renders.
- Doug Armand
So there isn't a way to prevent Blender from producing those empty frames?.fused wrote:Well, yes, sort of:
Shame as they add time to a render session - a 30 sec animation @30FPS needs 900 frames and generating those empties just adds to an already long process
Doug
Doug Armand
Doug Armand
I doubt they actually take any meaningful amount of time to create. What is taking up time is the export process, i.e. the scene processing, mesh and scene file writing to produce an Indigo scene file.Doug Armand wrote:So there isn't a way to prevent Blender from producing those empty frames?.
Shame as they add time to a render session - a 30 sec animation @30FPS needs 900 frames and generating those empties just adds to an already long process.
Users browsing this forum: No registered users and 92 guests
