Dear All
I am a newbie in using Indigo. I downloaded the Indigo Renderer and installed Blender 2.49b after I installed Python 2.6.2. The Blender console confirms that it found Python.
I split the Blender screen. One window I changed to Scripts window.
In the Scripts window I changed to Scripts->Render->Render with Indigo.
The GUI for Indigo Exporter appears.
When I press 'Render' in the Indigo GUI, the Indigo Renderer starts and then a window with the following message appears.
Message: A problem occurred with the scene:
SceneLoaderExcep: Unknown element type: metadata (In element 'metadata', around line 4, column 5)
Please contact support@indigorenderer.com.
Could anybody please help with I might be doing wrong?
Thanks in advance.
SceneLoaderExcep error
Re: SceneLoaderExcep error
Probably your Indigo version is too old for the exporter.
- Borgleader
car313 could you please specify which version of Blendigo and which version of Indigo you are using? Thank you.
Dear Borgleader
Thanks for the reply. I am using Indigo V2.2.12 and Blendigo 2.4 Stable.2.
By the way I downloaded Indigo 1.1.18 and Blendigo 1.1.18 and was very happy to see that it worked without any hitch.
I would still like to know how to make the Indigo 2.2.12 and Blendigo 2.4 Stable .2 work.
Thanks a lot!
Thanks a lot!
- Borgleader
If I recall correctly, Blendigo v2.4 is not backwards compatible meaning you have to use it with Indigo v2.4
