Blendigo works fine but not with external materials..
7 posts • Page 1 of 1
Cato
Post by Cato » Fri Dec 03, 2010 3:42 am
When I try to use an external material I get:
Python script error: check console
What does it mean?
Blender 2.49b
Blendigo 2.44
Indigo 2.4.13
Mac OSX 10.5.8
dougal2
Re: Blendigo works fine but not with external materials..
Post by dougal2 » Fri Dec 03, 2010 5:08 am
Check the console and find out?
For OSX, you need to open the System Console which I think can be found in Applications or Applications/Utilities.
Cato
Post by Cato » Fri Dec 03, 2010 6:50 am
Bild 9.png (7.03 KiB) Viewed 5104 times
That's what I found.
What materials were expected in the .pigm file?
Meelis
Post by Meelis » Fri Dec 03, 2010 8:49 am
Your material name has to be same in blender material interface as in indigo material.igm or.pigm
Open your material with material editor and see what's the name, change it if u like.
Cato
Post by Cato » Fri Dec 03, 2010 7:59 pm
Unfortunetely this didn't solve it. The problem is only with materials that have included textures or shaders. With textures I get "python script error..." and with shaders Indigo crashes after starting the render process.
Ok, the object in blender has to be uv mapped to the texture, that's clear, but in blender I can't load packed textures from .pigm files.
Post by CTZn » Sat Dec 04, 2010 8:06 am
Sorry if I'm missing the point, just catching your post on the fly:
pigm's are zip files. In Indigo there is also an item in the Tools menu to unpack pigm files.
:arrow: :arrow:
Cato
Post by Cato » Sat Dec 04, 2010 12:16 pm
That was exacatly, what I needed. Mercy beaucoup!!! :D
