Possibility to render spherical images?
9 posts • Page 1 of 1
galinette
Post by galinette » Sat Jan 23, 2010 11:06 pm
Dear all,
Is it possible to render "spherical" images? We could do for instance indigo-generated envmaps or QuicktimeVR pictures.
It is possible to render several pictures by rotating the camera and stitch them, but can it be done directly, for exemple in one lat/lon spherical EXR?
QuicktimeVR image of interiors rendered with indigo could be awesome.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Re: Possibility to render spherical images?
Post by PureSpider » Sat Jan 23, 2010 11:08 pm
I requested this back in the times when Ono was on IRC still.
All he responded was something like "build a script for rendering the faces of a cubemap"
So I doubt this will ever be implemented...
galinette
Post by galinette » Sun Jan 24, 2010 1:31 am
That's sad... I will continue to stitch with PTGUI
Etienne
Post by fused » Sun Jan 24, 2010 12:01 pm
Alex, back then, when Ono was still on IRC, Indigo wasnt commercial. Times change. So how would you know?
Rendering spehrical images, he told me, is easy to implement, but could not be used with bidirectional pathtracing. I'll bug nick to get that feature in 2.4 or 2.6 :)
Post by StompinTom » Mon Jan 25, 2010 2:18 am
Sweet cuz with a cube environment map, you'd get weird darkening because of camera vignetting which isn't disable-able, as far as I know.
Post by CTZn » Mon Jan 25, 2010 4:51 am
There is the solution to shoot a virtual probe, but Indigo doesn't seem to output EXRs (it used to, this was requested back). One might create an HDR from multiple tonemapped images tho.
Environment renders would be great !
Soup
Post by Soup » Wed Jan 27, 2010 2:27 pm
I know blendigo has a save as untonemapped EXR button under system > Image saving options.
Anyone know how/if this works?
dougal2
Post by dougal2 » Thu Jan 28, 2010 1:51 am
C:\Program Files\Indigo Renderer>indigo_console.exe -h
Indigo Renderer v2.2.11, Windows 32-bit Release build.
------------Usage:------------
indigo_console scene_path [options]
-h hostname[:port] Specify master hostname and port to connect to
-halt N Halt render after N seconds
-haltspp N Halt render after N samples per pixel
-igio out_path Path to write render IGI to
-image_save_period N Image save period (seconds)
-frame_upload_period N Frame upload period (seconds)
-n s Network render slave mode
-n m Network render master mode
-n wm Network render working master mode
-o out_path Path to write render PNG to
-p port Network render master port to listen on
-r igi_path Resume render using Indigo Image (.igi) found at igi_path
-seed N Use the random number generator seed N
-t N Use N render threads
-v Print out version information
-texro out_path Path to write tone mapped EXR to
-uexro out_path Path to write un-tone mapped EXR to
--ptest Performance test
--dumpmetadata png_path Dump PNG meta data from file at png_path
--pack scene.igs out.pigs Pack Indigo scene scene.igs to out.pigs
--unpack scene.igs out Unpack Indigo PIGS or PIGM to out
--tonemap scene.igs in.igi out.png Tonemap in.igi using parameters in scene.igs, to out.png
--thread_priority [belownormal|normal]
Post by CTZn » Thu Jan 28, 2010 4:56 am
Indeed... now how about <save_tonemapped_exr> and <save_untonemapped_exr> ?
After 10mn using both, only the png/igi pair has been written (multiple times)
Done 89350000.00000 samples (290.85286 samples per pixel)
149228.53332 samples / second (6.70113 micro-seconds / sample)
Saving Indigo image (.igi) to 'C:/work/3d/Indigo//renders/untitled.igs.igi'
	done.
Saving tone-mapped PNG to 'C:/work/3d/Indigo//renders/untitled.igs.png'
	Done.
Total render time elapsed: 10 m, 9 s
Done 90850000.00000 samples (295.73568 samples per pixel)
149168.43988 samples / second (6.70383 micro-seconds / sample)
but no exr created today were found onto my disks ... I'll test the flag.
