Null material vs. Clip/alpha map
5 posts • Page 1 of 1
Soup
Post by Soup » Thu Jan 21, 2010 11:54 am
While looking over SkIndigo, I noticed there was no null material, but there was a clip-map attribute for each of the material types.
I was wondering if anyone used the null material for anything other than a clip-map attribute would do?
Say, instead of blending with a null map for opacity/transparency just use the constant value of a clip-map to do the same. Same with a texture as the clip/alpha.
Thoughts?
Re: Null material vs. Clip/alpha map
Post by PureSpider » Fri Jan 22, 2010 1:43 am
Would be so much more convenient to use...
Are you talking about an exporter feature or an Indigo change here?
Post by Zom-B » Fri Jan 22, 2010 2:18 am
in Cindigo for example the whole usage of the null_material is done behind the curtains.
if you want to make a object (non specular related) transparent, simply check the blend box and set a % value.
if you want to clipmap a material with a BW texture, simply check blend and choose the clipmap texture... done!
I'm really thankful for this simplified integration :)
Post by CTZn » Fri Jan 22, 2010 2:36 am
I agree it's a good idea to do this at the exporter level, it's safer since all apps do not handle transparency the same way.
Soup
Post by Soup » Fri Jan 22, 2010 10:14 am
Zom-B wrote:in Cindigo for example the whole usage of the null_material is done behind the curtains.
I didn't know that :D
I think that's not such a bad idea, but perhaps would have to be a different workflow for other exporters, using 'blend' as opacity may go over other 3d package users' heads.
@purespider: Most definitely, all under the hood of the exporter.
So if the null material was taken out, and replaced with this transparency tool, would anybody miss it? The manual says it's only good for problem solving.
