Light Color temperature
11 posts • Page 1 of 1
Meelis
Post by Meelis » Fri Sep 18, 2009 7:49 pm
Hi
Is 6600K more or less white light in indigo?
And will object size affect light emitting intensity if setted to lm?
psor
Re: Light Color temperature
Post by psor » Fri Sep 18, 2009 8:11 pm
@Meelis
From my point a clear no! Please take a closer look.
And also keep in mind that what you see has to do with
the whitebalance and if you are using camera tonemapping
with the used camera response curve.
And now a clear yes to your second question. ;)
take care
psor
"The sleeper must awaken"
Meelis
Post by Meelis » Fri Sep 18, 2009 9:38 pm
So then 5250 in indigo is about white.
I found the 6600K from http://www.vendian.org/mncharity/dir3/blackbody/ but its more blue's greene's on my rendering.
How to use white balance - what are the x/y whitepoints?
psor
Post by psor » Fri Sep 18, 2009 10:18 pm
Probably you're right about the blackbody temp of
6600k then, cause the scale I've posted isn't for blackbody.
For (x,y) you should take a look at the technical manual.
I've used the presets only cause it's easier for me. ;)
Sorry for any confusion I might have caused. :roll: :twisted:
take care
psor
Meelis
Post by Meelis » Sat Sep 19, 2009 12:27 am
5000K D50 is white. Even too mutch. But It will do. I can lower it a bit.
Thanks for help.
Post by CTZn » Sat Sep 19, 2009 2:18 am
Meelis wrote:5000K D50 is white. Even too mutch. But It will do. I can lower it a bit.
Thanks for help.
It has to be white Meelis, that's what psor is telling.
Please refer to the Indigo (technical) Manual shipped with the application, page 35. You will find a plain explanation on the camera white point along with a usefull link to wikipedia.
Post by fused » Sat Sep 19, 2009 2:25 am
heres a list where you can find the right white point for your light temperature so that it will appear white in your rendering:
http://en.wikipedia.org/wiki/Standard_i ... lluminants
Post by PureSpider » Sat Sep 19, 2009 3:57 am
Thanks fused, nice link!
Meelis
Post by Meelis » Mon Sep 21, 2009 7:04 am
Yes very interesting data there. A bit late thanks to fused :D
Post by neo0. » Wed Sep 23, 2009 12:47 pm
Thanks fused. At first I didn't get it, but I think it'll come in handy. :)
Nick
Post by Nick » Wed Sep 23, 2009 11:39 pm
Little pattern:
Temperature Colore.jpg (15.57 KiB) Viewed 2841 times
