Don't know if this would be of use to anyone, but here are a couple sites with BRDF data in different formats.
http://www.graphics.cornell.edu/online/ ... index.html
http://www1.cs.columbia.edu/CAVE//software/curet/
I'm sure brdf is doable in Indigo, but as to how you can take these sources and get them to work... I haven't tried yet. I'm still a few Indigo versions behind, anyway. Anyone have an answer?
BRDF data sets
- TerraMatrix
I see, I'd assumed there was an established file format for profiles. Now I see that's not the case.
Does anyone know if this is something that absolutely must be done with precise instruments and exactly controlled conditions? Or could someone with the time and the technical skill build a scanner themselves? (of course if you hace unlimited funds you can pretty much do anything), but maybe a few thousand in this instance?
So far I've only found this to be of much help: http://www.cs.princeton.edu/~smr/cs348c ... paper.html
Written over 10 years ago. I didn't even know they were doing this that long ago!
