Linux Build 1.09 Stable Problems with wxgtk?
4 posts • Page 1 of 1
Colezero
Post by Colezero » Tue Jun 17, 2008 6:50 am
Hi everyone,
if i try to run the gui-indigo, my console tell me this:
Fatal Error: Mismatch between the program and library build versions detected.
The library used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.4,compatible with 2.6),
and your program used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.6).
Aborted
Is there a problem with the wxgtk?
But this is what is confusing me:
The library used [b]2.8 [/b]
and your program used [b]2.8[/b]
The console seems to run pretty fine, thou.
I don't want to use a windows build with wine, don't know why, but i don't like it. I like native.
greetings
Colezero
Post by Colezero » Mon Jun 23, 2008 1:07 am
No idea? Anyone?
I could use the console-edition. But blendigo got some problems with linux. No matter if i check Use Gui or not, it tries to open up indigo (GUI). Which ends up with:
 Fatal Error: Mismatch between the program and library build versions detected. [...]
So i need to export it, switch to a terminal an start indigo_console <scene>.igs manually every time i want to render it. Which is abit annoying.
Grimm
Post by Grimm » Mon Jun 23, 2008 12:03 pm
Are you running Fedora? There appears to be a problem with Fedora and it's wxgtk libraries. I tried Fedora 8 and had the same issue, don't know about 9. I switched to Ubuntu Hardy and it works fine now. ??
Grimm
Colezero
Post by Colezero » Tue Jun 24, 2008 3:52 am
Yeah iam using Fedora, and i recently switched to FC 9. With the same issues.
The source isn't available, is it?
