nakile
by nakile » Thu Dec 20, 2007 7:52 pm
I have the latest version of Darwine and Indigo installed, but whenever I try to render a Indigo file, I get this error in the Wine Log:
IndigoDriverExcep: IniFileExcep: could not open file 'inifile.txt'.
Fatal Error: IndigoDriverExcep: IniFileExcep: could not open file 'inifile.txt'.
Obviously, it can't read the inifile for some reason. Am I missing a dependency of some sort?
alexmeyer
by alexmeyer » Fri Dec 21, 2007 3:05 am
This problem came up before in IRC, and the solution was to run WineFile, and start indigo from that.
Let me know if this doesn't work...
nakile
by nakile » Fri Dec 21, 2007 8:11 am
Now a new error has popped up:
IndigoDriverExcep: SceneLoaderExcep: CSModelLoaderExcep: ModelFormatDecoderExcep for model 'z:\Applications\Indigo Renderer 1.0.4\prism\prism.3ds': Failed to read 3ds file 'z:\Applications\Indigo Renderer 1.0.4\prism\prism.3ds'. (In element 'mesh', around line 34, column 5)
I'm now going to assume that it can't read the 3ds file that the scene needs?
alexmeyer
by alexmeyer » Fri Dec 21, 2007 8:16 am
Yeah, it can't open that file. Make sure that file exists, that the path is correct, etc.
Is this your own scene, or one of the testscenes? Because there's a prism.3ds in the testscenes directory...
nakile
by nakile » Fri Dec 21, 2007 12:02 pm
It's working great now.
Very speedy! Now I just need to hope that Blindigo will work...
Edit: Seems as though Blender for Mac OS has no .blender folder. Where do I put the script?
tungee
by tungee » Fri Dec 21, 2007 11:21 pm
Load tinkertool, show unvisibles in Tinkertool,restart finderfrom tinkertoool,then you will find the scriptfoldere.
dougal2
by dougal2 » Sat Dec 22, 2007 2:09 am
OMG
darwine works on PPC processors too ?? !!
edit: oh, but it won't run x86 binaries. didn't think it would
ViennaLinux
by ViennaLinux » Sat Dec 22, 2007 1:12 pm
nakile wrote:It's working great now.
just use the bash? run "Terminal.app"
nakile
by nakile » Thu Dec 27, 2007 2:11 pm
Another problem. Now it seems to crash after rendering for around 12-18 minutes. No real hint as to why.
This is getting ridiculous.
ViennaLinux
by ViennaLinux » Fri Dec 28, 2007 2:31 am
I always restart to render with indigo
.. dont like this either.
How can I help to port it to Mac OS X?
What libraries causing problems so you cant build a Mac OS X binary?
by pixie » Sat Dec 29, 2007 4:58 am
I'm also having problems running indigo on darwine...
err:module:LdrInitializeThunk "MSVCR80.dll" failed to initialize, aborting
err:module:LdrInitializeThunk Main exe initialization for L"Z:\\Users\\vasco\\Desktop\\indigo_v1.0.4\\indigo.exe" failed, status c0000142
And gives me this pic:
- Error message
- Runtime error.jpg (39.14 KiB) Viewed 19101 times
kadajawi
by kadajawi » Tue Jan 08, 2008 7:20 am
Does anyone has an idea? I've started a network master on my Windows PC, the folder with all the data neccessary is shared and can be accessed on the Mac, the Mac runs a network slave version of Indigo and notices that a master has a job. Problem is that I've started the master via indigo.exe -n wm \\192.168.0.1\Cinema4D\11.igs, but OSX has a different naming scheme. Any idea how to solve that? I think now I'll try it by starting the client by hand, but it would be nicer to have that all done automatically...
dougal2
by dougal2 » Tue Jan 08, 2008 7:21 am
put the scenes in your indigo folder, and start the job with a relative path. that should work cross-platform.
kadajawi
by kadajawi » Tue Jan 08, 2008 9:44 am
Cool, thanks. Now it seems to work... ish.
Network slave connected from 192.168.0.2
ClientProxy: MySocketExcep: read failed, error: [unknown]
Dropping connection to slave.
Receiving frame from 192.168.0.2:
num_samples: 730000.000000
width: 1920
height: 1400
Frame received. (lock wait time: 0.00 s, transfer time: 17.27 s)
Is that behaviour ok?
kadajawi
by kadajawi » Wed Jan 09, 2008 3:31 am
Ok, it doesn't work. As soon as it sends the data it usually just loads the scene again. That way of course nothing gets done.
edit:
Did some testing. VMware + XP + Indigo works over the network, at half the speed (VMware should support dual core CPUs, but somehow it doesn't?). I'm trying Crossover, will try to find a Darwine copy to try out that too, rendering works, but not over the network. I discovered the error message "WSAEWOULDBLOCK", dunno how to solve that. Anyone got a clue?
