Can anyone tell me how to make use of the resume feature in 0.7?
Either just step by step here, or make an actual tutorial.
I'm sure many "people" like me would like to know.
Anyone write resume feature tutorial?
- joegiampaoli
To be able to resume a render:
Open up inifile.txt inside indigo dir.
Edit the line that says "save_igi" "false"
to
"save_igi" "true"
Then when you render, besides the normal PNG file in RENDERS directory you will have a file with .igi extension
When you stop a render and want to resume you have to do this...
indigo yourxmlfile.xml -r renders/theigifile.igi
That easy
to
"save_igi" "true"
That easy
- joegiampaoli
In my case I found that using full paths for the 3 terms of the command (indigo.exe, scene.xml and image.igi) was more secure... I mean afaik resume would fail if I don't use full path, that may help some folks...
Looks messy but that's the secure way I think.
C:\Progs\3d\indigo\indigo_07_test5\indigo.exe -r C:\Progs\3d\indigo\indigo_07_test5\renders\im1172610055.igi C:\work\3d\test\renderData\3dnoiz00_Indigo.xmlWho is online
