Parametric surfaces + shells
Re: Parametric surfaces + shells
Post by lycium » Sun Apr 15, 2012 12:08 pm
You're gonna need more polygons in this scene, I still see terminator artifacts ;)
no images to show here, yet...
Post by Whaat » Sun Apr 15, 2012 12:13 pm
:shock: lovin' these tests, ono. Give us more! :D
Post by OnoSendai » Sun Apr 15, 2012 12:27 pm
will do, tmrw :)
Post by StompinTom » Sun Apr 15, 2012 12:28 pm
:shock: Lookin' good!
rgigante
Post by rgigante » Sun Apr 15, 2012 7:15 pm
Thumb up! Great seeing first unbiased to implement native paametrics. NURBS to come?
Post by Zom-B » Sun Apr 15, 2012 10:33 pm
That looks really nice Ono, feed us with more!
Normal smoothing doesn't seem to kick in here ;)
Now please melt those all together with some metaball algo :P
Post by OnoSendai » Mon Apr 16, 2012 10:36 am
Scattered pebbles and shells.
50K pebbles and 100 shells.
Pebble and shell geometry are done with parametric surfaces.
Post by OnoSendai » Mon Apr 16, 2012 10:39 am
rgigante wrote:Thumb up! Great seeing first unbiased to implement native paametrics. NURBS to come?
NURBS will be implemented some day :)
Post by OnoSendai » Mon Apr 16, 2012 11:09 am
Another one:
Post by OnoSendai » Mon Apr 16, 2012 11:26 am
Sunset beach with narrower DOF.
Post by CTZn » Mon Apr 16, 2012 1:32 pm
Niiice !
I don't know if that's possible already but it would be useful to use a displaced mesh as scattering surface, ie displace a terrain then scatter peebles over. Adding details to the detail.
An alternative would be to be able to modify the peebles position by a shader (displacement for instance). The scattering would be generated before subdivisions but matching them.
Post by StompinTom » Tue Apr 17, 2012 3:13 am
OnoSendai wrote:Sunset beach with narrower DOF.
Ground just needs a bump texture (FBM?) and it would be perfect ;) Can you render one with 5M pebbles? Like, covering the ground completely?
Post by OnoSendai » Tue Apr 17, 2012 3:52 am
CTZn wrote:Niiice !
The scattered pebbles are already scattered over the parametric surface, which is already displaced. So the scattering does follow the detailed surface.
Post by OnoSendai » Tue Apr 17, 2012 3:53 am
Well, this one already has 1M small pebbles :)
Post by StompinTom » Tue Apr 17, 2012 4:02 am
Dare you to put 10M :twisted:
