network rendering central control program (C#)
- PureSpider
I'm using this:
purespider:/home/spider/indigo# mono --version
Mono JIT compiler version 1.2.2.1, (C) 2002-2006 Novell, Inc and Contributors. www.mono-project.com
TLS: normal
GC: Included Boehm (with typed GC)
SIGSEGV: normal
Disabled: none
Even when I run it under the mono wrapper in windows, it exits when I click the "Load Clients" button, but I probably would have to compile it with mono under windows, but I don't know how to compile it as a solution, they only give examples compiling *.cs files, but I need to be able to include dependencies, etc. Need to read the docs for mono compiling.
-niko
-niko
renderman support
hi I was wondering if it's posible to use this program renderman based renderers or mentalray or vray.
could someone here gave sugestions for the support of mentalray or renderman with this awsome queue manager
cheer,
james
cheer,
james
yeah but this program should also support other renderers
Sukrim wrote:There are several render managers out there (free ones too) that can handle renderman + mentalray just fine.
This one is just for Indigo (and doesn't have a queue manager I fear).
though the bittorrent style tracker is a really good idea and I can tell
you people would use this program if it had renderman or mentalray
support , I would just like to know what file or line in the c# source must I
edit for this to work.
cheers ,
james
- PureSpider
yeah but how do I add renderman support
or perhaps for lux render :
http://www.luxrender.net/
personally I think this tracker based render manager should have
support for various renderers such as renderman mental-ray and others
or just use pointers to link the manager to the renderer excuetable
for instance
[SETTINGS]
Tracker=10.209.76.61
aqsisPath=C:\Aqsis\bin\aqsis.exe
though would that work properly or would it require some more editing to the source code.
cheers ,
james
for instance
[SETTINGS]
cheers ,
james
- PureSpider
Actually a tracker could be written in PHP and SQL, but it's just that then you need a webserver and SQL database, so it does add some overhead. The main reason I made it this way for starters is to get something going for usage on a local network. I don't think internet rendering, at this time, is really going to be feasible with Indigo, since it doesn't even compress the frame data when it uploads it to the master. There may be a way to optimize that, but I haven't thought of it yetPureSpider wrote:@nikolatesla20: What about rewriting the tracker in PHP with MySQL support?
That way it would run on both linux and windows
Sukrim: could you explain to me what you mean by a render queue? It may be something that could be added if I knew what the needs were. Thanks.
kingcrimson: At this time I didn't write it with a ton of flexibility in mind, only for the current needs that I had. While a plugin architecture can certainly be added, it really is not suited for this purpose yet. But I appreciate the feedback.
-niko
