Need help for translating Indigo to non-english languages.
psor
Re: Need help for translating Indigo to non-english languages.
Post by psor » Fri Sep 25, 2009 1:11 am
fused wrote:
ZomB wrote:So please don't force the system language for the GUI but let it stay choose-able
at every point!
+1
very important!
+1 --> I always use english so don't enforce it on me ... I would go mad! :mrgreen: :mrgreen: :wink:
take care
psor
"The sleeper must awaken"
Post by OnoSendai » Fri Sep 25, 2009 10:55 am
Ok, I won't force it. But I guess the default should be the language/locale detected by the OS?
Post by pixie » Fri Sep 25, 2009 12:27 pm
OnoSendai wrote:Ok, I won't force it. But I guess the default should be the language/locale detected by the OS?
Should be set on install??
Post by Borgleader » Fri Sep 25, 2009 12:49 pm
What he said!
Post by OnoSendai » Fri Sep 25, 2009 1:01 pm
Install time isn't the easiest time to set it. Maybe when you first run Indigo you can choose the language, and thereafter it can be stored in the registry.
Post by Borgleader » Fri Sep 25, 2009 1:06 pm
OnoSendai wrote:Install time isn't the easiest time to set it. Maybe when you first run Indigo you can choose the language, and thereafter it can be stored in the registry.
if (langSET == false)
ask for language setting
dunno why i wrote it :lol:
psor
Post by psor » Fri Sep 25, 2009 1:53 pm
OnoSendai wrote:Maybe when you first run Indigo you can choose the language, and thereafter it can be stored in the registry.
That's cool with me! 8) :wink:
take care
psor
Post by Borgleader » Mon Sep 28, 2009 6:39 am
I've started to take a look at the Qt linguist file (I renamed it to indigo_gui_french.ts before fiddling with it). And I must say the program is quite easy to use, the hard part is actually translating it to something that doesn't sound dumb :?
Anyway I'll keep at it and see if I couldn't get through all the entries. :)
P.S: I had previously installed the entire Qt SDK for personnal projects so I didn't download the linguist package.
bmscmoreira
Post by bmscmoreira » Mon Sep 28, 2009 10:00 am
Hi all. I'd like to help translate Indigo to my language, Portuguese. If you are interested in this, please tell me.
Post by Borgleader » Mon Sep 28, 2009 10:28 am
It seems I'm having a little trouble translating some of the more "technical" terms, such as Tonemapping, Reinhard, ... and anything containing licensing in it as there isnt (to my knowledge) a french equivalent for it. The closest verb is "licencier" but that means to lay off someone :lol:
Also there was this particular entry which i found odd:
.QFrame{
border-radius: 5px;
background: qlineargradient(spread:pad, x1:0, y1:0, x2:0, y2:1, stop:0 rgba(200, 200,200, 255), stop:1 rgba(160, 160,160, 255));
.QLabel{
background: none;
color: white;
font-weight: bold;
And I was wondering if I should translate "toolBar" and "mainWindow" to something else or if I should leave them as is.
Post by OnoSendai » Mon Sep 28, 2009 10:32 am
Borgleader wrote: Also there was this particular entry which i found odd:
.QFrame{
border-radius: 5px;
.QLabel{
background: none;
color: white;
font-weight: bold;
Don't worry about that stuff :)
Also don't worry about 'mainWindow' and 'toolBar', that shouldn't be in there :)
Post by CTZn » Tue Sep 29, 2009 12:13 am
Hey Borgleader, the most accurate technical term for tonemapping in french is, I think, compression/compresseur tonal(e).
Below are a few derivatives that might fit as well, but my preference goes to the precited, again for accuracy.
compression/compresseur dynamique
modèle tonal
correction/correcteur tonal(e)
tonaliseur
you can open a language thread for further enquiries !
Cheesestraws
Post by Cheesestraws » Tue Sep 29, 2009 3:20 am
Borgleader wrote:It seems I'm having a little trouble translating some of the more "technical" terms, such as Tonemapping, Reinhard
Reinhard is a name. :)
bmscmoreira
Post by bmscmoreira » Tue Sep 29, 2009 6:12 am
Yes, I believe it was one of the author's of the particular tonemapping technique that got his name.
Post by Borgleader » Tue Sep 29, 2009 8:55 am
CTZn wrote:Hey Borgleader, the most accurate technical term for tonemapping in french is, I think, compression/compresseur tonal(e).
modèle tonal
tonaliseur
Wow thanks :)
@Cheesestraws: Thanks for the info :)
