Kosmokrator
by Kosmokrator » Tue Oct 23, 2007 4:03 am
i love the damn dispersion colors.....
hard to calc our cpus but worth the time!!!
psor
by psor » Tue Oct 23, 2007 11:37 am
@WytRaven
Thanx a lot for your contribution! I appreciate it very much!
take care
psor
"The sleeper must awaken"
WytRaven
by WytRaven » Tue Oct 23, 2007 12:28 pm
I will get around to doing much simpler test renders of each of the glasses at some point. Little thumbnails to help people select a glass based on visual appearance rather than on technical data.
I was thinking a sphere, a thin pane, and a semi-complex shape around 5cm in size each would make a reasonably good test scene without sending render times through the roof...
Sound good?
"A foolish consistency is the hobgoblin of little minds..." - Emerson 1841
psor
by psor » Tue Oct 23, 2007 12:59 pm
@WytRaven
Sounds good to me. If you need some help to render some scenes, I guess it
would be a good idea to split the work ... so I would offer some CPU time to
speed things up a bit. Maybe some others too ... hehe! ;o))
take care
psor
WytRaven
by WytRaven » Tue Oct 23, 2007 1:02 pm
Ok well I'll put to gether the scene tonite if I have some time and then run a test to find how many samples/pix is needed to give a reasonable result. Then I'll post the scene and we can organise who renders what
Thanks for the offer of help, much appreciated.
psor
by psor » Tue Oct 23, 2007 1:06 pm
You are very welcome and after all, for the community it is ... ^^
take care
psor
by Kram1032 » Wed Oct 24, 2007 4:18 am
suzanne or the teapot? both are nice objects to make test
Marcofly
by Marcofly » Wed Oct 24, 2007 4:27 am
your tests are very welcome, WytRaven!
The teapot is better than suzanne, but none of them are suited for a glass test, IMO.. You need an object that has a thickness similar to the real glass you want to reproduce, with a single layer (like a window glass)..
by Kram1032 » Wed Oct 24, 2007 4:40 am
couldn't you simply give them thickness? in Blender, there is the function "shrink/fatten", that will make things smaller/bigger on their normals' direction
- that should be possible in *any* app... (... as long as it's not specialized on architectural modelling.... I guess, sketchup doesn't have such a thing? - why should it^^ oh, and topmod *kinda* has it, but not the exact same thing...)
WytRaven
by WytRaven » Mon Nov 26, 2007 9:25 pm
DaveC
by DaveC » Mon Nov 26, 2007 10:24 pm
Man, that is an incredible thing you've done. You're patience must be almost limitless!
Thank you
Marcofly
by Marcofly » Mon Nov 26, 2007 11:10 pm
Thank you very much, wyt! a very useful work for the community!!
by Kram1032 » Tue Nov 27, 2007 2:36 am
OMG!!
Amazing list!
Do you have an exact time, how long all that together needed?
Yay, now, you can go on rendering your robot elements
by CTZn » Tue Nov 27, 2007 5:58 am
Big thanks wytRaven !
Differences are more visible in IoR and diffraction (cauchy), than absorption. Amazing how specular highlights change.
psor
by psor » Tue Nov 27, 2007 6:32 am
Holy cow! You did it, hehe! Awesome! Thanx a lot for your work mate! ;o))
take care
psor
