Kosmokrator
by Kosmokrator » Wed Aug 02, 2006 2:27 am
hi i make a coop test with 2 pc
1)master p4 ht 3ghz 1gb ram
2)slave celeron 705mhz 128mb ram
here is the results:
(master only)
Time elapsed: 5m, 18s
Done 19003000.000000 mutations (39.589583 mutations per pixel)
mutations_per_sec: 59644.905333
(master & slave)
Time elapsed: 5m, 20s
Done 22260500.000000 mutations (46.376042 mutations per pixel)
mutations_per_sec: 69386.489220
here is the reference images for compare...
[master only]
[master& slave]
u3dreal
by u3dreal » Wed Aug 02, 2006 11:18 am
Heee seems you got hold of the exporter .. great ...
but for the comparison ... the second PC with only 700MHz does not seem
to make a big difference here..
cheers
u3dreal
Kosmokrator
by Kosmokrator » Wed Aug 02, 2006 8:59 pm
yes the secont pc is slow but eventhis the diference between 2 images are great...imagine 4 p4 3ghz run ono project....
when we have an indigo update nicholas?
when we have an exporter update u3dreal?
u3dreal
by u3dreal » Thu Aug 03, 2006 12:25 am
??? what do you miss in the exporter right now... ???
i can't think of anything to update now
cheers
u3dreal
Kosmokrator
by Kosmokrator » Thu Aug 03, 2006 12:31 am
yes your exporter is great at this moment...i think we have wait for an indigo update first to add any new features to exporter...nick?u r on invacations now? Lets burn some keyboards while u code...
wzn
by wzn » Fri Aug 04, 2006 2:47 am
How many computers can be use by indigo? Unlimited?
Kosmokrator
by Kosmokrator » Fri Aug 04, 2006 2:58 am
hhmmm good question....anyone with large renderfarm?
psor
by psor » Fri Aug 04, 2006 3:13 am
Heya wzn,
I guess it depends on the power of the machine that you'll use to
run the manager on ... 'cause it has to combine the whole data. ;o)
take care
psor
Bullseye
by Bullseye » Tue Sep 19, 2006 7:51 pm
So any idea how well Indigo scales with more computers ?
Like would 1 machine that takes 12 hours to render a frame,
would 12 machines render it in 1 hour ?
cheers
Maluminas
by Maluminas » Tue Sep 19, 2006 10:37 pm
It all depends on the power of each machine. My main comp can render a given scene at 40k muts/sec while my older comp can render at 15k muts/sec. Add them by network and you get 55k muts/sec. But it also depends on your scene. One scene i made was rendered at 23 000 muts/sec on my main comp but only 300 muts/sec on my other comp
Youll need to experiment to see what speed boosts you can get
Bullseye
by Bullseye » Wed Sep 20, 2006 2:07 pm
Thanks Maluminas,
If I every get some free time, it will be spent playing with Indigo.
It looks brilliant.
