IGI combiner utility with source code
11 posts • Page 1 of 1
mgix
Post by mgix » Fri Feb 13, 2009 9:12 am
I have hit a scalability glass ceiling with the current Indigo network
rendering model for (sadly, master explodes past ~600 slaves, and
even when it doesn't, it becomes the bottleneck).
This has reduced me to have each "slave" dump IGIs to local disk,
collect them via scp and "manually" accumulate them into one final IGI.
To perform the final accumulation step, I wrote a litte tool that I thought
others might find useful.
There already is a tool that does this somewhere else in the forums, but
since I don't use windows and since the other tool that does has no source
code attached, I went a rewrote one myself.
It should work with recent IGIs (version 4, with layers).
Source code is here:
http://www.mgix.com/snippets/igiacc.cpp
Compile with:
g++ -g0 -O3 -fomit-frame-pointer -o igiacc igiacc.cpp
Windows binary is here:
http://www.mgix.com/snippets/igiacc.exe.bz2
Use as follows:
igiacc *.igi
Enjoy,
- Mgix
Post by PureSpider » Fri Feb 13, 2009 9:24 am
Does this compile on windows?
mgix
Post by mgix » Fri Feb 13, 2009 9:37 am
PureSpider wrote:Does this compile on windows?
Now it does.
Post by CTZn » Fri Feb 13, 2009 9:39 am
Your contribution is much apreciated mgix... necessity is the mother of all innovations ;)
You can find the equivalent for windows, from dougal2:
http://www.indigorenderer.com/joomla/fo ... t=igimerge
SATtva_
Post by SATtva_ » Fri Feb 13, 2009 11:34 pm
mgix, I have trouble compiling it under amd64 with both GCC 3.4:
/tmp/ccoQbIYZ.o:(.gnu.linkonce.d.DW.ref.__gxx_personality_v0+0x0): undefined reference to `__gxx_personality_v0'
collect2: ld returned 1 exit status
...and 4.1/4.2:
/tmp/ccxKzTLI.o: In function `isBigEndian()':
igiacc.cpp:(.text+0x26): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x42): undefined reference to `__cxa_guard_release'
/tmp/ccxKzTLI.o: In function `main':
igiacc.cpp:(.text+0x406): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x42b): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x44b): undefined reference to `__cxa_guard_release'
igiacc.cpp:(.text+0x45a): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x47a): undefined reference to `__cxa_guard_release'
igiacc.cpp:(.text+0x4d4): undefined reference to `__cxa_guard_release'
igiacc.cpp:(.text+0x54a): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x56a): undefined reference to `__cxa_guard_release'
igiacc.cpp:(.text+0x579): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x599): undefined reference to `__cxa_guard_release'
igiacc.cpp:(.text+0x5b7): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x5d7): undefined reference to `__cxa_guard_release'
igiacc.cpp:(.text+0x683): undefined reference to `__cxa_guard_acquire'
igiacc.cpp:(.text+0x69f): undefined reference to `__cxa_guard_release'
/tmp/ccxKzTLI.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
Any assumptions or prerequisites I failed to met?
mgix
Post by mgix » Sat Feb 14, 2009 12:32 am
SATtva_ wrote:mgix, I have trouble compiling it under amd64
No, I just wrote my post too hastily.
The correct command line to compile should read 'g++' instead of 'gcc'.
I'll go correct my post now.
Cheers
SATtva_
Post by SATtva_ » Sat Feb 14, 2009 12:46 am
:D
Yeah, this makes much difference. =)
Post by OnoSendai » Sat Feb 14, 2009 2:40 pm
Hi Mgix,
I've updated the IGI spec here:
http://www.indigorenderer.com/joomla/fo ... sc&start=0
mgix
Post by mgix » Tue Feb 17, 2009 10:39 am
OnoSendai wrote:Hi Mgix,
Hey Ono,
Thanks for taking the time to update the specs, but ...
if you happen to have time, a little more is needed :)
Because the compiler is free to align and pad things any way it
chooses, only giving a C++ class layout isn't enough: it makes
your spec compiler dependent.
As a practical example of what I mean, gcc and VC++ currently
have different ideas of what sizeof(IndigoImageHeader) version 4 is.
I copied the class code verbatim from your spec into a small c++
program, and ...
With GCC: sizeof(IndigoImageHeader) is 5028
With VC++: sizeof(IndigoImageHeader) is 5032
Which is the correct answer ?
Does the image data start at offset 5032 or at offset 5028 ?
It could potentially be inferred from the overall size of the file
and the spec'd size of the pixel data, but I don't think that'd be
a very nice thing to have to rely on.
Also, if you do rely on sizeof(IndigoImageHeader) inside indigo's code
when writing out IGIs, your format will not be stable across platforms,
compilers or even different releases of the same compiler ...
mgix
Post by mgix » Tue Feb 17, 2009 11:56 am
Update: to answer the plea of the pour souls still stuck with windows,
I have ported igiacc. I've also added a link to a binary in the original
post.
Post by OnoSendai » Thu Feb 19, 2009 3:18 pm
Hey Ono,
You are of course quite right mgix. I've updated the IGI spec to add another 4 bytes to the padding, to reflect the size of the structure that VS was producing. I've also added a more explicit description of the padding, or lack thereof, that should be expected on disk.
Sorry about that!
Users browsing this forum: No registered users and 196 guests
