Yafaray - Indigo
13 posts • Page 1 of 1
skypa
Yafaray - Indigo
Post by skypa » Mon Nov 13, 2006 3:25 pm
Greetings,
a little comparison.
Yafaray:
Indigo:
The original scene and Yafray render is from lakcaj.
I tried to mimic all the original materials, apart from the floor which could have used a little higher exponent it's looking alright I think. The lighting of the original scene was accomplished bei two large area lights on the ceiling and on the wall in the back off-camera, small area lights in the shelve. I removed those area lights (duh) and just used mesh emitters where the spots on the ceiling and in the shelve were. The TV screen texture has a 10 gain, to give it a little fake-emission, the two boxes are uv textured cubes, so I couldn't do anything about them ;). It's Reinhardt tonemapping with a Post of 2.
Both images rendered for ~4 hours. I had a little noise removal done, thus the floor texture on the latter picture is a little washed out. The ceiling lamps look weirdly pixelated, any ideas about that?
edit ps:
yes, it's yafaray (thanks chronoh), the actively maintained rewrite of the yafray core
oodmb
Post by oodmb » Mon Nov 13, 2006 3:32 pm
are you sure the top one is yafray and the botom one is indigo and not the other way around? although the bottom one looks more photorealistic, the top one seems to have more of that exponent floor texture and is also showing a little more noise (which i attribute to indigo rather than yafray)
however if it is the right way indigo has realy gotten way cleaner than yafray and deffinitly looks better
skypa
Post by skypa » Mon Nov 13, 2006 3:39 pm
oodmb wrote:are you sure the top one is yafray and the botom one is indigo and not the other way around? although the bottom one looks more photorealistic, the top one seems to have more of that exponent floor texture and is also showing a little more noise (which i attribute to indigo rather than yafray)
Trust me, the above is Yafaray, the other one is Indigo. :)
edit: The bottom floor lacks exponent, hence is a little too glossy. I was too lazy to correct that. ;)
oodmb
then wow
Post by oodmb » Mon Nov 13, 2006 3:41 pm
ok. i guess indigo is finaly far beyond the power of yafray
Lotuspec
Re: then wow
Post by Lotuspec » Mon Nov 13, 2006 7:46 pm
oodmb wrote:ok. i guess indigo is finaly far beyond the power of yafray
While I do agree about indigo being superior quality-wise, you should not forget that the yafray renderer probably didn't need quiet as much time as indigo to achieve its result. So I'd say neither is better, it just depends on the what you use it for.
skypa
Re: then wow
Post by skypa » Mon Nov 13, 2006 7:52 pm
Lotuspec wrote:While I do agree about indigo being superior quality-wise, you should not forget that the yafray renderer probably didn't need quiet as much time as indigo to achieve its result. So I'd say neither is better, it just depends on the what you use it for.
Well, I agree in general, but this particular scene rendered exactly the same time both with Yafray and Indigo. :)
Animation, walkthroughs and what not are of course still Yafray domain, but other than that.. especially interiors are owned by Indigo right now.
Phil
Post by Phil » Tue Nov 14, 2006 8:31 am
really interesting,
thanks a lot for this comparison, and also for giving some parameters you used with indigo.
(I never used Yafray but I find this result really good)
I just find the shadow a little strange in your version.
Thanks again, regards
Phil
tungee
Post by tungee » Tue Nov 14, 2006 8:33 am
yafaray isnt yafray!
it s a new build of samo!
skypa
Post by skypa » Tue Nov 14, 2006 8:45 am
tungee wrote:yafaray isnt yafray!
Not quite, it's a new build of Lynx. :)
@Phil
Well, since it's the unbiased approach I'm not sure what to say about the shadows. They may be weird, but I guess if you'd build such a room with the same lamp setup, the shadows would probably look like that, I don't know.
tungee
Post by tungee » Tue Nov 14, 2006 8:48 am
you re right its lynx creation.#
hi skypa, how do you run yafaray?
skypa
Post by skypa » Tue Nov 14, 2006 8:53 am
tungee wrote:you re right its lynx creation.#
It's a little tricky and involves recompiling Blender. Read more about it here.
tungee
Post by tungee » Tue Nov 14, 2006 8:45 pm
thanx skypa!
tungee
Post by tungee » Tue Nov 14, 2006 8:46 pm
so the fryrender is made by a ex yafray guy? :shock:
Users browsing this forum: No registered users and 66 guests
