Indigo 1.0.4 on OS X Leopard+Darwine
15 posts • Page 1 of 1
nakile
Post by nakile » Thu Dec 20, 2007 7:52 pm
I have the latest version of Darwine and Indigo installed, but whenever I try to render a Indigo file, I get this error in the Wine Log:
IndigoDriverExcep: IniFileExcep: could not open file 'inifile.txt'.
Fatal Error: IndigoDriverExcep: IniFileExcep: could not open file 'inifile.txt'.
Obviously, it can't read the inifile for some reason. Am I missing a dependency of some sort?
alexmeyer
Post by alexmeyer » Fri Dec 21, 2007 3:05 am
This problem came up before in IRC, and the solution was to run WineFile, and start indigo from that.
Let me know if this doesn't work...
nakile
Post by nakile » Fri Dec 21, 2007 8:11 am
Now a new error has popped up:
IndigoDriverExcep: SceneLoaderExcep: CSModelLoaderExcep: ModelFormatDecoderExcep for model 'z:\Applications\Indigo Renderer 1.0.4\prism\prism.3ds': Failed to read 3ds file 'z:\Applications\Indigo Renderer 1.0.4\prism\prism.3ds'. (In element 'mesh', around line 34, column 5)
I'm now going to assume that it can't read the 3ds file that the scene needs?
alexmeyer
Post by alexmeyer » Fri Dec 21, 2007 8:16 am
Yeah, it can't open that file. Make sure that file exists, that the path is correct, etc.
Is this your own scene, or one of the testscenes? Because there's a prism.3ds in the testscenes directory...
nakile
Post by nakile » Fri Dec 21, 2007 12:02 pm
It's working great now.
Very speedy! Now I just need to hope that Blindigo will work...
Edit: Seems as though Blender for Mac OS has no .blender folder. Where do I put the script?
tungee
Post by tungee » Fri Dec 21, 2007 11:21 pm
Load tinkertool, show unvisibles in Tinkertool,restart finderfrom tinkertoool,then you will find the scriptfoldere.
dougal2
Post by dougal2 » Sat Dec 22, 2007 2:09 am
OMG :shock: darwine works on PPC processors too ?? !!
edit: oh, but it won't run x86 binaries. didn't think it would :x
ViennaLinux
Post by ViennaLinux » Sat Dec 22, 2007 1:12 pm
nakile wrote:It's working great now.
just use the bash? run "Terminal.app" 8)
nakile
Post by nakile » Thu Dec 27, 2007 2:11 pm
Another problem. Now it seems to crash after rendering for around 12-18 minutes. No real hint as to why.
This is getting ridiculous. :?
ViennaLinux
Post by ViennaLinux » Fri Dec 28, 2007 2:31 am
I always restart to render with indigo :-( .. dont like this either.
How can I help to port it to Mac OS X?
What libraries causing problems so you cant build a Mac OS X binary?
Re: Indigo 1.0.4 on OS X Leopard+Darwine
Post by pixie » Sat Dec 29, 2007 4:58 am
I'm also having problems running indigo on darwine...
err:module:LdrInitializeThunk "MSVCR80.dll" failed to initialize, aborting
err:module:LdrInitializeThunk Main exe initialization for L"Z:\\Users\\vasco\\Desktop\\indigo_v1.0.4\\indigo.exe" failed, status c0000142
And gives me this pic:
Error message
Runtime error.jpg (39.14 KiB) Viewed 18561 times
kadajawi
Post by kadajawi » Tue Jan 08, 2008 7:20 am
Does anyone has an idea? I've started a network master on my Windows PC, the folder with all the data neccessary is shared and can be accessed on the Mac, the Mac runs a network slave version of Indigo and notices that a master has a job. Problem is that I've started the master via indigo.exe -n wm \\192.168.0.1\Cinema4D\11.igs, but OSX has a different naming scheme. Any idea how to solve that? I think now I'll try it by starting the client by hand, but it would be nicer to have that all done automatically...
dougal2
Post by dougal2 » Tue Jan 08, 2008 7:21 am
put the scenes in your indigo folder, and start the job with a relative path. that should work cross-platform.
kadajawi
Post by kadajawi » Tue Jan 08, 2008 9:44 am
Cool, thanks. Now it seems to work... ish.
Network slave connected from 192.168.0.2
ClientProxy: MySocketExcep: read failed, error: [unknown]
Dropping connection to slave.
Receiving frame from 192.168.0.2:
num_samples: 730000.000000
width: 1920
height: 1400
Frame received. (lock wait time: 0.00 s, transfer time: 17.27 s)
Is that behaviour ok?
kadajawi
Post by kadajawi » Wed Jan 09, 2008 3:31 am
Ok, it doesn't work. As soon as it sends the data it usually just loads the scene again. That way of course nothing gets done. :(
edit:
Did some testing. VMware + XP + Indigo works over the network, at half the speed (VMware should support dual core CPUs, but somehow it doesn't?). I'm trying Crossover, will try to find a Darwine copy to try out that too, rendering works, but not over the network. I discovered the error message "WSAEWOULDBLOCK", dunno how to solve that. Anyone got a clue?
