textured emitters
Post by Kram1032 » Sat Jun 23, 2007 4:43 am
hum, shure... maybe, it can be converted. dunno :)
anyway - brightness differences are too complex to get them correctly by 256 steps, in many cases. :)
Post by Whaat » Sat Jun 23, 2007 4:46 am
Great work as always Ono!
Looking forward to the next release!
daniel_nieto
Post by daniel_nieto » Sat Jun 23, 2007 8:56 am
i can barely see i0.9 ... :)
Image From México, Daniel Nieto .·.
arneoog
Post by arneoog » Sat Jun 23, 2007 9:07 am
:shock:
Now I can make as many fancey, glowing name tags as I want! :D
Sweeeet 8)
:P
Labello
Post by Labello » Sat Jun 23, 2007 11:02 am
OnoSendai wrote:
Kram1032 wrote:would that be so much differrent from a JPG-converted .exr?
-that's an other request, btw: can we use .exr for those emitters? :D
Not sure if this would be useful.. most exrs are spherical or lat/long env maps
But there also exists the possbility 2 create own HDR-images... so if isnt a that great effort to implement it... that would be great! :D
ThatDude33
Post by ThatDude33 » Mon Jun 25, 2007 7:39 am
This is a great addition! 8)
Matt B. >>Maya To Indigo<<
mrCarnivore
Post by mrCarnivore » Mon Jun 25, 2007 7:14 pm
Just because most .exr happen to be used for HDRI and therefore re latlong/spherical doesn't mean that you can't use the .exr format for something else. :-)
Especially for emitters (or hdri, which is just the same as emitters basicly) it makes very much sense to use a hdr format like .exr. There do exist non-latlong/spherical .exr in the web and you could easily create your own.
rgigante
Post by rgigante » Mon Jun 25, 2007 8:26 pm
Great add Ono, thanks so much!
But, not to appear annoing, when do u think will be introduced the material code reorganization u mentioned?
Frankly i admit that today's materials definition is not the best, due to the presence of alot of different materials shaders (phong, diffuse, glossy_transparrncy, specular, diffuse_transmitter, blend_material, null_material together with all the different kind of mediums). Probably, please correct me if wrong, including a single BDSF shader provided also with emissive capabilities (like happens for MW and Radium) will make mat definition (also for exporter writers) more productive.
IMHO i think this is the most important step to be done before goin on and on in adding other feature since this could contribute to define a more robust and coherent material architecture for next future feature implementation.
Last, is the number of UV-set for embedded mesh still fixed to 4? I suggested alot of time ago to extend the number of UV-set to an higher number due to the introduction of blend-material... any news?
Hoping to see the new material definition i do really thank you again for your effort.
Best regards, Riccardo.
